Rotel RDD-1580 on the way
Postby cmh714 » 07 Aug 2014, 16:57
Should be getting here in the next several days. Had email with one of their engineers, and he has it working with RaspyFi so I am reasonably sure I can get it working with Rune.
Will post back on it after it arrives.
Re: Rotel RDD-1580 on the way
Postby cmh714 » 13 Aug 2014, 16:34
Arrived last night at 6:30pm and had it sort of up and running in no time at all.... I am having issues with the DAC getting a clean feed from the Pi.
For the most part, 44.1 plays normal, but anything at a higher rate has clicks, pops, and white noise, that gets worse as you go up in bitrate. 88.2 and 176.4 dont play at all, just a ton of white noise.
Any help would be most gratefully appreciated....I can post debug if anyone thinks that will help.
I am going to try v0.2 to see if its any better, since we know there are issues with 0.3 and higher bitrates....will also try some other ditros...
Postby ACX » 13 Aug 2014, 17:24
Postby Orion » 13 Aug 2014, 17:25
Try to use this fix.
schiit-modi-dac-t288.html#p1860
Let me know if it works.
Simone.
- Embedded Hi-Fi music player
Orion
Postby ACX » 13 Aug 2014, 17:29
And as last resource you could try suggested by tux some time ago.
Postby cmh714 » 13 Aug 2014, 17:49
Thanks ACX....basically thats what I was going to try....anything and everything :)
Will keep you posted...and since I have 6 SD cards at the ready, I was definitely going to burn 0.2 again. Right now, I am enjoying a '77 Grateful Dead soundboard, but will be testing later.
was also seeing if amixer had any options for me to try....
thx again!
Postby cmh714 » 13 Aug 2014, 17:58
In the meantime, heres my debug: http://pastebin.com/G4UwrtLV
Please let me know if you see anything useful for me to jack around with.
Postby Orion » 13 Aug 2014, 18:06
Orion
Postby cmh714 » 13 Aug 2014, 18:07
Postby cmh714 » 13 Aug 2014, 18:11
Return to Compatibility list
