RPi 3 B+
Re: RPi 3 B+
Postby tml3nr » 27 Jul 2018, 15:05
tml3nr
Re: RPi 3 B+
Postby occhio37 » 27 Jul 2018, 15:28
;) thank you, should have read it all the way....
occhio37
Re: RPi 3 B+
Postby mxbmb » 01 Aug 2018, 21:04
mxbmb
Re: RPi 3 B+
Postby fox.peko » 07 Aug 2018, 11:43
I am write in case of freeze playback window . I have connected usb external 500GB disk 2.5'
with 19 000+ songs around.Everything is slow or freeze when I load fully playlist. Is some possible fix for it . It is little bit wierd. Pc, phone work with this quantity without any problems.
Thank you for any answear.
fox.peko
Re: RPi 3 B+
Postby tml3nr » 09 Aug 2018, 15:10
tml3nr
Re: RPi 3 B+
Postby fox.peko » 10 Aug 2018, 04:59
fox.peko
Re: RPi 3 B+
Postby tml3nr » 10 Aug 2018, 14:26
tml3nr
Re: RPi 3 B+
Postby tml3nr » 10 Aug 2018, 14:30
tml3nr
Re: RPi 3 B+
Postby fox.peko » 11 Aug 2018, 10:20
No did not try another hdd. Btw, I damage my power supply yesterday ;) . I will receive new 4A one, and I try another hdd too. I hope it will be fine. I will write.
Thank you
fox.peko
Re: RPi 3 B+
Postby fox.peko » 17 Aug 2018, 10:27
I tried change the HDD , power supply but without any good changes. But I found problem, maybe. When I try command top memory is full but swap 0 used how I can enable swaping to sdcard memory is it possible?
fox.peko
Users browsing this forum: No registered users and 43 guests
