RPi 3b+ latest version?
Postby kolmberger » 03 Dec 2020, 09:41
Hey there,
I got a bit lost in the versions of the images here and could not get the firmware linked on the mainpage running at all... Hope you can help me out, I am looking for the latest image for my Rpi 3b+.
I found a link to these version: runeaudio-r-e6-t7141.html
--> a Version from 2020-02-12, right?
But also found this: runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532.html
--> a Version from 2018-09-03, right?
So, do I have to go with the upper version?
Thanks and cheers! :)
kolmberger
Re: RPi 3b+ latest version?
Postby ceejayemm » 03 Dec 2020, 10:15
Kolmberger
The most up to date version of RuneAudio is RuneAudio R+e6 which can be found here:
Follow the instructions in the first post of that thread and you should be good to go. I also use a PI 3B+ with this version and its great.
Regards.
Chris
ceejayemm
Postby kolmberger » 03 Dec 2020, 10:58
Edit: I will post my issue here --> post30714.html#p30714
Hey Chris,
Thanks a lot for the hint, I got it up and running now, after I clicked "update". Then I was able to connect Wifi and bluetooth.
Now I'm a little stuck with getting sound over bluetooth to my speaker. The bluetooth pairing succeeded, I can see my speaker as active (green light in GUI).
Could you tell me, what the proper setting in MPD or System (profile?) is?
Thanks again.
kolmberger
Postby ceejayemm » 03 Dec 2020, 17:04
Klumberger
Sorry can't help you with Bluetooth as its not something I use.
Chris
ceejayemm
Postby rastus » 04 Dec 2020, 04:13
rastus
Users browsing this forum: Bing [Bot] and 6 guests
