[SOLVED] RPi Audio Jack
Postby dnaman » 05 Feb 2014, 18:22
OK, I've installed Rune Audio, found all my audio files on my NAS and it appears to play them.
I had assumed that for test purposes, I could simply plug headphones into the RPi audio jack but I'm getting no output. Have I made a wrong assumption? I believe I have configured the sound path correctly under MENU but I'm open to suggestions in that area.
dnaman
Re: RPi Audio Jack
Postby ACX » 05 Feb 2014, 19:55
Hi dnaman, please go to MENU > MPD and check if Analog output is selected.
Re: RPi Audio Jack
Postby dnaman » 05 Feb 2014, 22:46
Hi ACX,
Yes, Analog out is enabled, along with Volume Control - software
dnaman
Re: RPi Audio Jack
Postby dnaman » 05 Feb 2014, 23:28
Update:
I just tried another Raspberry Pi and it works OK on that one. Both are Model-B's - the one that works has 256 MB ram, the one that doesn't has 512 MB.
I don't suppose that extra memory would prevent the analog audio from working so it looks like there might be a hardware problem with that one. Bummer, I just bought that one a few weeks ago and hardly used it.
dnaman
Re: RPi Audio Jack
Postby ACX » 06 Feb 2014, 00:49
That's strange, we have here both versions (256 MB and 512 MB) and it works fine on both.
Can tou report some debug infos please?
Re: RPi Audio Jack
Postby dnaman » 06 Feb 2014, 22:54
ACX, I'm embarrassed. I finally did what I should have from the start and tried another headset ...... and it worked with both RPi's.
Anyway, I'm a happy camper and off to play. Thanks for your help
(How do I mark this as "solved" - do I do that or do you?)
dnaman
Re: RPi Audio Jack
Postby ACX » 07 Feb 2014, 00:16
I'll mark it, thanks for the feedback.
