Rpi B+ v0.3 + AudioQuest DragonFly V1.2 = No sound
Postby thanhvo31 » 13 Nov 2014, 16:53
Kindly have a look at my issue NO SOUND
Rpi B+ v0.3 sound nicely with HRT microstreamer and TEAC UD-501, but no luck with DragonFly V1.2
I had try Volumio, also no luck. DragonFly worked nicely with Windows box or Android 5.0.
Below is my debug
Thank you.
thanhvo31
Re: Rpi B+ v0.3 + AudioQuest DragonFly V1.2 = No sound
Postby cmh714 » 13 Nov 2014, 17:12
I guess reading and searching through the forums is too difficult for you......as this has been addressed a bunch of times.....my DragonFly works just fine in my B+
try checking your alsamixer
Postby thanhvo31 » 13 Nov 2014, 17:52
Actually I had google a lot and try alsamixer but no luck. Could you post your debug data on working Pi+ Dac? Thanks.
thanhvo31
Postby cmh714 » 13 Nov 2014, 18:27
interesting...then I assume you hit the F6 key in alsamixer to select the DAC? it will take me a bit to switch my setup over to get the debug info for you. Currently my B+ is plugged into my Rotel DAC, but I will take the time to swicth over for you.
From what I see of your debug it looks good, but I aint no expert.
Postby cmh714 » 13 Nov 2014, 21:19
Heres my pastebin for you to look at: http://pastebin.com/Z2VCednv
My setup is DragonFly and my powered USB hub are in 2 of the USB slots of the Pi. My wireless and USB drive are plugged into the hub. For this debug, I removed the drive so it wont show up in there.
Also I have the version 1 of the DragonFly....I see you have DSD enabled but I dont believe that it can do DSD...
Re: Rpi B & Rune v0.3 + AudioQuest DragonFly V1.2 = No sound
Postby thanhvo31 » 15 Nov 2014, 17:36
Still no luck here. Pi B +DragonFly V1.2, try with alsamixer,.. both Rune and Volumio.
I am trying with Pi MusicBox now and see...
thanhvo31
Postby ACX » 15 Nov 2014, 17:54
Hi thanhvo31,
have you tried to switch between different kernel version? You can do that right from the UI in the Settings screen (a reboot is required after that). Try to pick a older kernel and see if there's come difference.
Postby thanhvo31 » 15 Nov 2014, 18:54
thanhvo31
Postby anadigi » 15 Nov 2014, 20:03
anadigi
Postby cmh714 » 16 Nov 2014, 01:23
for 0.3beta I did NOT have to switch any kernels or the startup parameters. for the 0.3alpha I did make those changes as I have documented in other threads on this issue.
I suppose if you really want I can try and make you an image for you to test with from a backup of mine.....
