RPi.GPIO for LED, Push Button, Relay Module
Postby rern » 26 Sep 2016, 14:57
Re: RPi.GPIO for LED, Push Button, Relay Module
Postby dunghnguyen » 30 Sep 2016, 16:55
Thanks @rern for the tutorial. I can learn a bit from this. Let me to see if I can manage time to create some scripts running on Rpi0 to control RPi2 / Rune [WINKING FACE]
I hope even I can create the RPi that it controls itself when pressing the button . In this case, can you advise if we can use another pin for pin 40 instead since we often pin 40 as the DAT of i2s connection to external DAC?
dunghnguyen
Postby rern » 03 Oct 2016, 03:06
Of course you can use any pin+ground pairs except 3.3V and 5V power supply pins.
Postby dunghnguyen » 03 Oct 2016, 03:19
dunghnguyen
