RPi + Runeaudio +Wifi as Accesspoint
Re: RPi + Runeaudio +Wifi as Accesspoint
Postby Joe90 » 23 Sep 2016, 23:48
OK
So I guess it is raspbian -> accesspoint, mpd and mpddroid for me then ;)
Thanks for the pointers, Frank :)
Joe90
Postby hondagx35 » 24 Sep 2016, 09:12
Postby Joe90 » 24 Sep 2016, 12:06
Yay, that works :)
Can connect to the UI using the Chrome browser on my phone.
However, if I try using the RuneAudio app all I get is a black screen with a small half graphic of an upside down Android logo in the top left corner?
Will try a reinstall of the app......ahh that fixed it :)
Looking good to go. Now to get it fired up in the car :)
Many thanks Frank - will write up full howto for RPi Model B in due course.
Joe90
Postby johnbanks » 24 Sep 2016, 13:10
Frank ...
Wireless AP can be made to happen for the old model B, Pi 2 & Pi 3 and with a range of wireless dongles. The instructions are a little bit different in each case though.
So I repeat my suggestion that you make this thread 'sticky' so it appears at/near the top of the forum topic listing.
Your thoughts?
johnbanks
Postby Joe90 » 24 Sep 2016, 13:29
RPi B:
Hmmm
No soundcard?
Connecting USB (stick or HDD) knows is connected, but shows nothing in Library
Joe90
Postby nathanashton » 13 Oct 2016, 11:05
This solution works great but I'm trying to get it working with a different scenario.
I'd like the Pi to be connected either via Ethernet or WiFi to the local network. Then if it is unplugged or away from the network, the AP functionality would kick in.
nathanashton
Postby hondagx35 » 13 Oct 2016, 11:20
Postby nathanashton » 13 Oct 2016, 23:30
Thanks Frank,
It all seemed to work well without issue until I connected the Wifi to my local network. Since then the AP never comes up, even with Ethernet disconnected, Router turned off and a reboot. If I delete the saved profile and reboot then the AP becomes visible again as expected.
nathanashton
Postby Runebeginner » 20 Oct 2016, 20:37
Runebeginner
Postby hondagx35 » 20 Oct 2016, 21:51
Hi Runebeginner,
seems like you missed this step
* modify /var/www/command/refresh_nics
Users browsing this forum: Bing [Bot] and 54 guests
