RPI2 v1.2 runeaudio don't launch
Postby telecofr » 01 Jan 2017, 10:19
Hello
Happy new year !
I buy the new rpi2 v1.2 and I download RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img, but when I supply the rpi, runeaudio don't launch...
Can you modify your software to be suitable with the new rpi2 v1.2 ?
thank you
telecofr
Re: RPI2 v1.2 runeaudio don't launch
Postby Techwiz » 28 Jan 2017, 05:20
Techwiz
Postby hondagx35 » 28 Jan 2017, 11:25
Hi Techwiz,
i am working on a new RP2 V1.2 compatible image.
The only thing you have to do is to update kernel and firmware.
- Get a RP2/RP3 and boot rune.
- kernel and firmware
- boot your Pi2 (V1.2) with your updated SD card.
Or you can copy the new to your SD card using a PC / Pi running linux.
Postby Techwiz » 28 Jan 2017, 21:34
Frank,
Thank you for the prompt reply. I've downloaded the kernel file you posted and have had slightly more success. Still running into the issue of the green activity light eventually coming on solid and the software stop responding. I'll post more details later once I have a chance to more thoroughly try things out.
Regards,
Techwiz
Techwiz
Postby Techwiz » 30 Jan 2017, 04:23
Techwiz
Postby thedman! » 04 Feb 2017, 22:44
This is the same problem I had/have. Unfortunately am virtually a novice so can offer no help at all. I monitor these forums reasonably regularly in the hope it will be fixed. I'm in no rush... but rune is amazing, I can't believe I fried my pi3 and then got an unsupported 2. As soon as a fix is found I'll be using it!
thedman!
Users browsing this forum: Google [Bot] and 3 guests
