RPi2 + wifi does not connect
Postby brughiera » 20 Jan 2017, 15:25
Hi, first of all thanks for your work!
I have a strange issue latest version of Rune running on Raspberry Pi 2. I have a usb wifi card attached, correctly recognised, and I can see in the UI the SSID of the network I want to connect to. I enter the password, click on "save" but nothing happens. It doesn't connect, and overall there seems to be nothing going on. Any idea of what's going on? Is there any how-to for the command line approach? Apparently it doesn't work the same as Raspbian...
Thanks!
brughiera
Re: RPi2 + wifi does not connect
Postby brughiera » 20 Jan 2017, 16:23
BTW, to be more specific:
I tried following this:
but had no success.
brughiera
Postby hondagx35 » 20 Jan 2017, 18:12
Postby brughiera » 25 Jan 2017, 21:08
thanks a lot for your reply, and sorry for replying so late. In the end I went down the manual netctl path, following arch wiki. The missing part of information was that rune uses netctl. Wifi connection now works, great. Thanks!
brughiera
