RPI3 Bugfix proposal for mpd.conf generation (SB11040)
Postby uwedamm » 03 May 2017, 20:12
within /var/www/app/libs/runeaudio.php
in the function wrk_audioOutput
The following lines for the mpd.conf are generated:
> device "hw:x,y"
The code fails for my sound-card like follows:
$description = sysCmd("aplay -l -v | grep \"\[".$card."\]\"");
error_log($description[0]);
> card 0: U0x41e0x30d3 [USB Device 0x41e:0x30d3], device 0: USB Audio [USB Audio]
$subdeviceid = explode(':', $description[0]);
error_log($subdeviceid[1]);
---> The problem is the additional ":" for my USB sound-card (0x41e:0x30d3)
$desc = array();
$subdeviceid = explode(',', trim($subdeviceid[1]));
> empty, because of "',' not found"
$subdeviceid = explode(' ', trim($subdeviceid[1]));
> empty again
$data['device'] = 'hw:'.$card_index.','.$subdeviceid[1];
error_log($data['device']);
> hw:0,
Result--> the trailing "0" is missing in the mpd.conf and I cannot use the soundcard
Proposal:
proposal: instead of first explode'ing by ':', start with ','
error_log('UWE: '.$description[0]);
$subdeviceid = explode(',', $description[0]);
error_log('UWE: '.$subdeviceid[1]);
$subdeviceid = explode(':', $subdeviceid[1]);
error_log('UWE: '.$subdeviceid[0]);
$subdeviceid = explode(' ', trim($subdeviceid[0]));
error_log('UWE: '.$data['device']);
Anybody here, who can check, if my proposal works fine for all the other vendors?
If YES, you may update the runeaudio.php in the next release?
thank you
Uwe
uwedamm
Users browsing this forum: No registered users and 34 guests
