RPI3 + Hifiberry Digi+ problem with setting up
Postby TripleSec » 09 Apr 2017, 12:16
Hello everyone,
I am trying to set up Raspberry PI 3 + Hifiberry Digi+, but I can't get it to work.
I am using: RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img
I followed the instrucions from hondax35 post from here: hifiberry-dac-not-detected-after-kernel-update-t4180.html
1) Firstly I resized partition
Before resizing it looks like this:
Resizing:
After resizing:
Is it done correctly?
2) Then I tried to update kernel and firmware, so I pasted to ssh console this:
pacman -Sy --force raspberrypi-firmware-bootloader linux-raspberrypi
and then this:
pacman -Sy --force raspberrypi-firmware raspberrypi-bootloader linux-raspberrypi
3) I then edited config.txt (I didn't touch "config.txt.pacnew")
*uncommented: dtoverlay=hifiberry-digi
*added line below: dtparam=audio=on
4) Deleted the file /etc/modules-load.d/ras....conf using ssh
5) Changed the kernel name
___________
After inserting Hifiberry digi+ card I can't connect to runeaudio.
What can be done in this case?
Debug file copied before inserting Hifiberry digi+: https://pastebin.com/bE1ryvpX
Edited config.txt: https://pastebin.com/PaBsQjXX
config.txt.pacnew: https://pastebin.com/7pX7mhn0
TripleSec
Re: RPI3 + Hifiberry Digi+ problem with setting up
Postby hondagx35 » 09 Apr 2017, 12:35
Hi TripleSec,
for some unknown reason, your HW does not get detected correctly.
please try version.
Postby TripleSec » 09 Apr 2017, 12:49
ok, are those instructions (hifiberry-dac-not-detected-after-kernel-update-t4180.html) the same for this version?
TripleSec
Postby hondagx35 » 09 Apr 2017, 12:55
Postby TripleSec » 09 Apr 2017, 14:15
It doesn't work :cry:
I chose Hifiberry Digi on the settings page, then power off, then insert Hifiberry card and I can't access runeaudio on my browser.
Here is debug file (before inserting hifiberry card): https://pastebin.com/MWujVhtk
edit: I have borrowed RPI2 from a friend and it doesn't work too (with Hifiberry card inserted)...
Any ideas?
TripleSec
Postby hondagx35 » 09 Apr 2017, 17:59
the image works with Hifiberry Digi+ (pro) see .
To be sure not to have a defective card, I would try the Hifiberry .
You also can try .
Postby TripleSec » 10 Apr 2017, 19:02
I tried disabling EEPROM, but it didn't help. Does it matter where do I put this line (force_eeprom_read=0) in config.txt?
About Hifiberry test image:
I installed Raspbian and then established connection through SSH. Does it automatically mean that the card is working correctly?
How can I play some sample audio to test it? [headless - I have no HDMI monitor]
TripleSec
Postby Stephane » 10 Apr 2017, 20:03
Stephane
Postby TripleSec » 10 Apr 2017, 21:28
So, does it mean the card is defective?
Should I configure it somehow or it should work out-of-the-box?
TripleSec
