Run service at startup
Postby nathanashton » 03 Nov 2016, 03:08
Hi All,
I've got a rotary encoder installed on the Pi which uses a daemon to control the MPD volume. It works find as long as I start the process manually from the command line. I've been using systemctl to install it as a service. The service starts fine on boot and the daemon process seems to be running but it doesnt work.
I understand RuneAudio is an implementation of Arch. Is there anything Rune specific that I need to do to get a service to run at boot?
nathanashton
Re: Run service at startup
Postby waves » 03 Nov 2016, 22:18
I run a few services at boot. See for instructions on running a python script at boot, which might be of help when troubleshooting.
waves
Postby nathanashton » 04 Nov 2016, 04:38
Got it all sorted. The process I had would not run unless MPD was already running. I added a timer to the service with a 1 minute delay and it seems to work fine now.
Cheers
nathanashton
Postby hondagx35 » 04 Nov 2016, 09:57
