RUNE Audio and Brutefir (Convolver for Roomcorrection)
Re: RUNE Audio and Brutefir (Convolver for Roomcorrection)
Postby theSuede » 19 May 2015, 15:33
theSuede
Postby tux » 05 Jun 2015, 21:05
tux
Postby Da Alchemist » 12 Dec 2015, 17:49
Sorry for being absent a long time :oops: . Fact is I do not use Runeaudio any more because i did not understand how to compile things by myself on Arch. :oops:
I gave some tips on the other forum, but the steps in Rune are basically the same. I do not use the other "Player" either, but I do use MPD. At the moment i use the pi as player DSP (Room Correction) and Crossover sending multichannel PCM via HDMI to an AVR. This deserves some Kernel modification.
https://volumio.org/forum/volumio-with- ... t3635.html
Da Alchemist
Postby danhilu » 16 Dec 2015, 22:05
Hi Da Alchemist,
Thank you for posting, this his helpfull.
You mention "i use the pi as player DSP (Room Correction) and Crossover sending multichannel PCM via HDMI to an AVR".
With multichannel do you mean 2 (right / left) or 4 or 6 (i.e. left right combined with low / med / high) ?
In case you managed to output 4 or 6 channel to PCM via HDMI on the Raspbery Pi I would be very gratefull to have details (and I would not be alone see http://rtaylor.sites.tru.ca/2013/06/25/ ... are-howto/ no solution yet on the Pi).
Danke im voraus fuer deinen Feedback
Daniel.
danhilu
Postby cmsgarb » 17 Dec 2015, 06:31
hi Da Alchemist,
regarding regarding brutefir on Runeaudio I have one question. how did you manage to edit mpd.conf permanently. I also tried brutefir on Runaudio but observed thar after reboot I get the original mpd.conf
Best Regards
Christian
Gesendet von iPad mit Tapatalk
cmsgarb
Postby Da Alchemist » 20 Dec 2015, 13:56
Da Alchemist
Postby cmsgarb » 20 Dec 2015, 23:29
thanks.....
cmsgarb
Postby Da Alchemist » 23 Dec 2015, 08:19
@danhilu
I gave some advice to the multichannel thing here: http://www.diy-hifi-forum.eu/forum/show ... stcount=87
Da Alchemist
Postby jrubins » 15 Feb 2016, 05:08
jrubins
Postby AlleyCat » 27 Feb 2016, 22:44
Hi there,
I have been setting up filets with MiniDSP for a while and am familiar with measuring acoustics. I am specifically interested to run the filters on the RuneAudio. I followed the tutorials provided by Da Alchemist and info posted at https://volumio.org/forum/volumio-with- ... t3635.html. Thank you all!
I am getting no sound to the DAC. Can you please review where my configuration may fail?
Hardware is Pi2B with HiFiBerryDAC+.
RuneAudio is 0.3beta with GUI update.
MPD is 0.19.6-1
play -l
[root@rune2 home]# aplay -l
card 0: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
Output section of /etc/mpd.conf
audio_output {
type "pipe"
name "brutefir pipe"
command "/usr/local/bin/brutefir -nodefault /home/.brutefir.conf 2>/dev/null"
format "44100:32:2"
.brutefir.config
sampling_rate: 44100;
filter_length: 32768,16;
overflow_warnings: true;
float_bits: 64;
input "left", "right" {
device: "file" {path: "/dev/stdin";};
sample: "FLOAT64_LE"; # sample format
channels: 2; # number of open channels / which to use
delay: 0,0; # delay in samples for each channel
maxdelay: -1; # max delay for variable delays
mute: false,false; # mute active on startup for each channel
output "left", "right" {
# device: "file" {path: "/dev/stdout";};
device: "alsa" { device: "hw:0,0"; };
sample: "S16_LE"; # sample format
maxdelay: 100; # max delay for variable delays
dither: false; # no dither for 32 bit output
# factor 0.4 to avoid clipping
filter "M direct" {
from_inputs: "left"//0.4, "right"//0.4;
to_filters: "left direct", "right direct";
coeff: -1;
crossfade: false;
# here 0.8 instead of 0.4 because the filter "in average" multiplies with 0.5
# (one could make 0.8 a bit larger/smaller to obtain a wider/narrower
# stereo image, but better use RACE for this)
filter "S filter" {
from_inputs: "left"//0.8, "right"//-0.8;
#coeff: "S channel";
coeff: -1;
crossfade: false;
filter "left direct" {
from_filters: "M direct"//1.0, "S filter"//1.0;
to_outputs: "left"/0.0;
#coeff: "left_default";
coeff: -1;
crossfade: false;
filter "right direct" {
from_filters: "M direct"//1.0, "S filter"//-1.0;
to_outputs: "right"/0.0;
#coeff: "right_default";
coeff: -1;
crossfade: false;
Thank you
AlleyCat
AlleyCat
Return to DIY and tweaks
