Rune Audio and BubbleUpnp
Postby transfers » 21 Feb 2017, 01:30
I am running BubbleUpnp on my Android phone to stream from my NAS to a Raspberry Pi running Rune Audio headless.
The Pi IP address is dynamic, but everytime it changes, BubbleUpnp loses connection with the Pi.
I can restart BubbleUpnp but it won't find the Pi unless I restart the Pi.
However I can still control the Pi with a browser direct to Rune Audio.
I would prefer to use BubbleUpnp as it has better search functions.
I've tried to give the Pi a static IP in Rune but I'm not having much luck with that at the moment.
As far as I can see, Rune won't save a static IP unless you update to the nightly build.
When I follow the instructions here , it stops at 61%. Restarting gives you a dead Pi.
So I have two questions:
1. Does BubbleUpnp lose connection when you use a dynamic IP?
2. If so, how can I set a set a static IP in Rune Audio?
I'm cross posting this on Rune Audio and BubbleUpnp just in case.
RuneAudio 0.3-beta for Raspberry Pi 2B with Hifiberry DAC+
BubbleUpnp 2.8.7 licensed
transfers
Re: Rune Audio and BubbleUpnp
Postby hondagx35 » 21 Feb 2017, 10:12
Postby DomieMic65 » 21 Feb 2017, 15:04
It's not related to the initial question but as long as it's BubbleUpNPs thread...
How can I stream Spotify (premium) to Rune (RPi3) though BubbleUpNP?
I can stream local files from my phone but not Spotify! Is this a feature of the unlocked BubbleUpNP?
Thank you!
Sent from my Nexus 5X
DomieMic65
Postby transfers » 21 Feb 2017, 22:22
transfers
Postby transfers » 21 Feb 2017, 22:26
transfers
Postby DomieMic65 » 22 Feb 2017, 07:53
DomieMic65
