Rune Audio never survives turning off
Postby Stavros » 25 Jan 2014, 11:58
On first installation, Rune audio works great, but after turning off (either by choosing the menu option, or pulling the plug) it will never boot up a second time.
Stavros
Re: Rune Audio never survives turning off
Postby supertrogg » 25 Jan 2014, 12:18
I too have suffered this. I thought it was just me being a berk!
Powering off isn't the only time I've seen this behaviour. Sometimes just a seemingly innocuous config change causes this!
I found that nothing but a reinstall brings it back!
supertrogg
Postby Stavros » 25 Jan 2014, 15:41
Should have said, I'm using a Raspberry Pi 256MB rev 2 and a pcm2704 USB DAC. RuneAudio v0.2beta
Stavros
Postby Orion » 04 Feb 2014, 17:51
Hi Stavros,
we had a couple of feedbacks similar to your situation (we are still working on debug).
Surely a part of the problem is .
On shutdown you may have to wait a lot of time, especially if you use CIFS mount points, prior to disconnect the AC adapter from your RuneAudio player.
This is connected with a known bug of Systemd.
We hope to solve this problem as soon as possible.
- Embedded Hi-Fi music player
Orion
Postby Stavros » 06 Feb 2014, 15:32
Stavros
Return to Bug report
