Rune Audio not showing or allowing rebuild of library
Postby CityCentreFox » 25 May 2019, 10:54
Good Morning All
I have just tried to play some music and my library isn't showing any music. Also when I try to rebuild it or update it, it does the update/rebuild but then still shows nothing.
I have checked the drive and that is fine.
Has my image corrupted?
CCF
Kind Regards
CityCentreFox
Using:
Raspberry Pi 3 Model B+
Pi - DAC - Pro
Pioneer Amp
Tannoy 609 SE Speakers
Monster Speaker Cable
Cambridge Atlantic Audio Cable
CityCentreFox
Re: Rune Audio not showing or allowing rebuild of library
Postby janui » 25 May 2019, 11:56
Postby Toube » 25 May 2019, 14:06
Yeah same problem here.
-Toube
Toube
Postby CityCentreFox » 25 May 2019, 14:16
Hi Janui
Thank you for your response. I appreciate all your efforts, especially to my previous queries.
Also I previously asked on another thread about the rune audio app not connecting to a Sky Q router. I am not sure if you had seen it?
When I open the app all I get is a blank screen with a little half android logo in the top left. The app worked perfectly with my previous Sky router.
I have tried both 2.4 & 5 Ghz wireless and the problem is still there.
Is this a known issue with the Sky Q router? I can connect to the player with Microsoft Edge using 192. etc.
As always kind regards
CCF
Kind Regards
CityCentreFox
Using:
Pi - DAC - Pro
Pioneer Amp
CityCentreFox
Postby dynobot » 25 May 2019, 20:48
Same problem here on all of my Rune installs.
:o
BTW, Janui thank you for your time and effort with Rune and for looking into this issue.
dynobot
Postby gearhead » 26 May 2019, 02:29
My runes all came back to life. Don't know what happened, but I got spinning discs on all 3 at home, here. Then about 2pm, they started working again.
Gearhead
gearhead
Postby Toube » 26 May 2019, 06:14
Mines are still facing the issue.
And yes thanks Janui for taking time to have a look at this issue.
-Toube
Toube
Postby englishtim » 26 May 2019, 10:21
Hi Everyone,
The problem, at least with my setup, seems to be that something (one of the online services?) has simply become very slow - the good news is that Rune's behaviour appears to return to normal after a delay of about 20 seconds or so. The delay also happens when switching between the 'Playback' and 'Library' views.
Janui: it would be helpful to know which online services are used by Rune - could you share some information about that, please? Thanks in advance for your efforts to fix this!
Peace and friendship,
englishtim
englishtim
Postby janui » 26 May 2019, 12:21
Hi Everyone,
This problem has been traced to an outage at last.fm. Rune uses last.fm API's for various features. When internet is not available Rune works fine, but when these services are available but do not work properly Rune fails. The good news is that the service is up and running again. So, everything seems to be working. I intend to modify the code so that it will be more resilient to possible future outages.
In addition, last.fm is no longer providing album art or artist images. These disappeared a couple of weeks ago, but it seems to be a permanent change, see here: https://getsatisfaction.com/lastfm/topi ... reply-list In all cases a ‘star’ image is provided instead of the expected album or artist artwork. We are working on a solution for this.
Postby CityCentreFox » 26 May 2019, 12:26
Hi All
Just to let you know that mine is now running again albeit slightly clunky. As englishtim previously posted you just have to be a bit patient on connection.
Skipping between playback and library is a sporadic regarding times but it gets there eventually.
Any posters give any insight to my connection issues regarding the app and Sky Q router?
Again Regards
CCF
Kind Regards
CityCentreFox
Using:
Pi - DAC - Pro
Pioneer Amp
CityCentreFox
Users browsing this forum: Bing [Bot] and 20 guests
