rune audio on raspbian and directly connect to amplifier
Postby glda19 » 02 Feb 2014, 16:42
I see that the download is based on archlinux.
But i have already onther projects that running on raspbian can i install rune audio on raspbian
Can i use it with no usb dac
glda19
Re: rune audio on raspbian and directly connect to amplifie
Postby Melomane » 02 Feb 2014, 17:18
volumio (volumio.org) is based on debian. Runeaudio/Arch Linux are not compatible with raspian. E.g. the init-scripts are very different.
Yes, you can connect rpi direct to your amp.
Melomane
Postby glda19 » 02 Feb 2014, 17:32
volumio is that only the software ore also raspbian
glda19
Postby Melomane » 02 Feb 2014, 17:41
runeaudio is arch linux + nice Web-GUI for mpd + a few tweaks for a better playing of musicfiles.
volumio is raspian + nice Web-GUI for mpd + a few tweaks etc. ... ;)
If you don't need the Web-GUI, you can do an apt-get install mpd, configure it and choose a client from a long list:
http://mpd.wikia.com/wiki/Clients
Melomane
Postby glda19 » 02 Feb 2014, 17:56
is it posible to isntall volumio with appt-get install
glda19
Postby Mte90 » 04 May 2014, 11:28
I use the raspberry for a ftp server to sync two pc with two pc. I have raspbian so it's very impossible to install runeaudio on debian?
Professional #Geek, #Developer, #Debian user, #FirefoxOS Training Lead Italy, #KDE/#QT lover, Zagoriano, Moderator of #Wordpress Italy Plus
Mte90
Postby ACX » 05 May 2014, 18:41
Postby Mte90 » 09 May 2014, 11:39
there is some custom setting on this debian for nginx and other software.
Mte90
