Rune UI is slow
Re: Rune UI is slow
Postby Golgi » 31 May 2019, 10:37
Yes, works like a charm.
Thanks RandomRuneUser, good job!
Golgi
Golgi
Re: Rune UI is slow
Postby englishtim » 31 May 2019, 11:31
Hi Everyone,
Works here too - thanks to RandomRuneUser for the fix!
Please note that - unsurprisingly - Dirble no longer works when the fix is applied. I don't use it here, but those of us who do use it should just be aware...
Peace and friendship,
englishtim
englishtim
Re: Rune UI is slow
Postby dragos_nedelcu » 31 May 2019, 15:21
Works perfectly!!!!!! Thank you!!!!!
dragos_nedelcu
Re: Rune UI is slow
Postby dragos_nedelcu » 31 May 2019, 15:31
Faster than first install. Thank you RandomRuneUser!!!!!!!!!
dragos_nedelcu
Re: Rune UI is slow
Postby Ears of Tin » 31 May 2019, 20:12
Here's another thank you for the fix. Working great and I got to use SSH for the first time.
Ears of Tin
Re: Rune UI is slow
Postby Colin » 31 May 2019, 20:21
This is due to the Dirble http://api.dirble.com/ not responding anymore.
I've not found a way to disable it yet, will look into it.
Edit: I've made a merge request that adds a setting to disable it : https://github.com/gearhead/RuneUI/pull/18
Colin
Re: Rune UI is slow
Postby Tantal » 01 Jun 2019, 10:51
The interface works as usual again,
without editing any files.
:mrgreen:
Rune version: 0.4 (build: beta-20160313) on RB Pi2 + HiFi-Berry
Tantal
Re: Rune UI is slow
Postby tml3nr » 01 Jun 2019, 10:57
tml3nr
Re: Rune UI is slow
Postby Toube » 02 Jun 2019, 16:14
Works like a charm, great work @RandomRuneUser thanks.
-Toube
Toube
Re: Rune UI is slow
Postby anana » 05 Jun 2019, 08:41
This resolved the issue. (Added wildcarded dirble.com to my pihole blacklist.)
It may work now even faster than before. Thank you!
anana
