Postby bgeneto » 24 Jul 2014, 21:51
ACX, no problem with 0.2 beta. Just wrote "RuneAudio_rpi_0.2-beta.img" in a clean RPi SDCard, didn't touch any settings, nothing (since my USB DAC was already selected as output)... just added one samba share with minimal sample hi-res flac files and those files plays incredible fine (even via Ethernet, minor pops/clicks maybe because I’m still not using I2S). Then I burned “RuneAudio_rpi_0.3-alpha_20140710_2GB.img” again since in my current setup I have already made some changes (like git update, removed RPi output etc…). This time just added the same source/library (no other changes) and voila… 48kHz (see attached pictures while playing the same 24/192kHz file in both runeaudio versions).
THT.
bgeneto
Postby cmh714 » 24 Jul 2014, 22:27
what was the git update?? I mustve missed that somewhere along the way....I saw the post about using the v2 setting in v3 for a future update to fix this issue.
Postby cmh714 » 24 Jul 2014, 22:37
Got a B+ the other day. Backed up my running .3 setup from the B, restored on new sdcard, booted up fine just having troubles with wireless since it didnt kick in like I expected.
working on it now.... :)
EDIT: a few reboots and bam, its working....go figure
Postby cmh714 » 24 Jul 2014, 23:31
Ok, it may have a bit more power and 4 USB ports but it still doesnt have enough juice for an external USB HD which isnt the hugest problem
Postby ICLlP » 24 Jul 2014, 23:44
One thing I've noticed with 0.3 alpha (the first Rune I've been able to use) is that if I add an album to the playlist with "add, replace, play" the played tracks remain in the playlist after completion. In Volumio the get lost once they are completed; I prefer this. Hopefully Rune can do the same. In everything else I am preferring Rune to Volumio.
ICLlP
Postby cmh714 » 25 Jul 2014, 00:42
Postby cmh714 » 25 Jul 2014, 00:44
SMB/CIFS mount through UI fails to an OSX share.
smb.conf seems to be missing/link broken so that could be one issue I suppose. Havent had a chance to try and troubleshoot it.
Postby Bjarne » 25 Jul 2014, 06:35
Bjarne
Postby Bjarne » 25 Jul 2014, 06:37
Bjarne
Postby ICLlP » 25 Jul 2014, 08:05
ICLlP
Users browsing this forum: Bing [Bot] and 106 guests
