Postby hikingpickle » 08 Aug 2014, 13:07
Started seeing a problem with samba mounts on 0.3. On first install i can successfully mount from OS X Server and mpd updates ok. I use the SMB/CIFS (OS X share) and the relevant username / password. After a reboot the share will not remount (red x next to it in the UI), seeing this in the log although the credentials are unchanged
[ 2361.781638] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 2361.781710] CIFS VFS: Send error in SessSetup = -13
[ 2361.783983] CIFS VFS: cifs_mount failed w/return code = -13
If i then remove and recreate the share using the UI and the same settings I can still not connect. If I flash a brand new copy of the install image and create the share it works fine until a reboot.
I can connect successfully to this share from other linux machines, i.e., nothing has changed on the server. Where is the configuration for the mounts kept in the filesystem? I suspect authentication method has changed / not been saved?
On a possibly related note if i then try and run smbclient to interrogate the server it complains that smb.conf can not be opened and in fact there seems to be a dangling symlink:
lrwxrwxrwx 1 root root 45 Jan 15 2014 smb.conf -> /var/www/_OS_SETTINGS/etc/samba/smb-prod.conf
The directory /var/www/_OS_SETTINGS does not exists although there is a dir /srv/http/app/config/_os which seems to contain the same files.
hikingpickle
Postby johnbanks » 08 Aug 2014, 18:24
I'm successfully running 0.3 ALPHA on an RPi/Wolfson rig - streaming from my NAS by wireless using nfs
There is no ethernet cable connected.
I also have some test tracks on a connected USB stick.
After a reboot, my USB is mounted again but my NAS nfs export is not mounted (red X). It is necessary to REMOUNT ALL. The Library does an Updating which takes approx 20 or 30 secs and then everything is OK once more.
I have seen an error comment ...... Mount nfs: Network is unreachable.
Could it be that the NAS mounting is attempted before wlan0 is up?
Here's my debug report:
http://pastebin.com/C0KnkQTh
johnbanks
Postby johnbanks » 09 Aug 2014, 17:10
Can someone please explain the the purpose of the SWAP partition (third one) that is created on the SDHC?
I have moved the SYSTEM partition (second one) to a USB stick and altered the config_wosa.txt to boot from the USB stick .
I'm running the Wolfson image.
My SDHC only has the FAT Boot partition and everything seems to be running OK.
johnbanks
Postby Pazze » 12 Aug 2014, 15:21
In love with RuneAudio!
I've been testing the 0.3-Alpha and I ran past a bug in the UI that prevents you from connecting to Wireless Networks with a WhiteSpace in the SSID. (Apologies if this has already been reported)
When you click on a SSID with a WhiteSpace eg: 'wlan xyz' the resulting link will be 'wlan%20xyz'. (for obvious html limitations)
The UI apparently takes the url as SSID which doesn't work. 'wlan%20xyz' doesn't exist.
Pazze
Postby anana » 12 Aug 2014, 17:57
Hi there,
been testing this beta for a couple of days now. First using a SMB2 share, then NFS one. Same files, same directory.
Shares/library build seems to take nearly 10 hours.. I hope there is or will be an option for incremental rebuilds. :)
And When it's finally finished (judging from fileserver proc list as nfsd/smbd fades away from taking processor time) I only see a fraction of folders in my Library. Is there some kind of file/directory limit I should be aware of? I only see letters A-G for now.
However, thru "search in DB" -box, I can reach all the files - even the invisible majority - and enqueue them as normal.
My music library consists of 79053 files in 5440 directories.
Other than this, it's the best and most functioning/responsive RPi player and UI I've tested so far. Keep up the good work.
anana
Postby ICLlP » 12 Aug 2014, 19:46
ICLlP
Postby PhM » 13 Aug 2014, 09:29
PhM
Postby ACX » 13 Aug 2014, 11:48
Postby hikingpickle » 14 Aug 2014, 21:13
hikingpickle
Postby cmh714 » 15 Aug 2014, 02:57
So for those having issues with 24bit files of all sample rates (but worse as you get higher), stuttering, white noise, sounds like someones playing the "spoons" to your music, try this......
1. First follow this post that was for the Schiit MODI here: schiit-modi-dac-t288.html
2. Second, you can read this post: my-solution-to-pops-and-clicks-t165.html
BUT.... even easier, it seems the Guys already included number 2 above in 0.3.
Edit /boot/cmdline_rune.txt
Mine has five lines, first 3 rem'ed, 4 is "active, and fifth rem'ed. The fifth line is the same settings from the Schiit MODI posts. Change that and reboot, and hopefully you will profit.
I changed from the AudioQuest DragonFly to a Rotel RDD-1580 and this is working great, with maybe some minor issues at 176 and 192 only. And very minor overall. It did take about 16 hours of screwing around with any number of things.
YMMV and GL!!!
