Postby ICLlP » 15 Aug 2014, 08:16
ICLlP
Postby hikingpickle » 15 Aug 2014, 11:45
hikingpickle
Postby ICLlP » 15 Aug 2014, 17:05
ICLlP
Postby johnbanks » 17 Aug 2014, 16:31
Message to ACX and the guys ...
Would you please publish the code that is run when one clicks on the REMOUNT ALL SHARES button.
I'm thinking it might be possible to set up a cron job that runs after a reboot.
Thanks in advance
johnbanks
Postby ACX » 18 Aug 2014, 01:52
Postby Surson » 18 Aug 2014, 15:31
Will the 0.3 version compatible with the new Hifiberry DAC+ (the Raspberry B+ version)?
Thanks.
Surson
Postby ACX » 18 Aug 2014, 16:49
Postby franz159 » 18 Aug 2014, 19:17
franz159
Postby wick » 18 Aug 2014, 23:12
I have 3 main issues with the 0.3 alpha version.
1. Using the DragonFly: I get sound output from streaming radio, but it is very very muted, nearly inaudbile.
playing w/ alsamixer doesn't seem to have an effect, nor does playing w/ hw, sw, no volume.
Perhaps I am missing something silly (as often happens). It seems like this should have a simple fix.
So, I am not getting any real music out. (The same is true when I try my Wolfson Dac, with the Wolfson
kernel selected, but I will save that for a later post and its particular debug info)
The other issues are important, but more 'minor', in descending order of importance.
2. My external usb (fat32) mounted successfully, and is visible at the top level as belonging
to my library, but browsing it picks up nothing at all - no way to see any music files.
(Rebooting after it is removed -- system state still thinks it is there, on the browser side)
3. The wlan0 setup does not work for me since I use an unsecured local network, and so the wpa supplicant
biz goes off the rails, it seems. Selecting a static IP worked briefly, but only that - it got the SSID,
etc., but this went away very quickly.
If someone can tell me what files to change, I can do it manually, as I have with my (dozens!) of home
computers of various sorts (including many rpi's and bbb's, etc.)
How was this done in version 0.2?
It *is* much faster, I am sure it will be much better.
Here's the debug info.
http://pastebin.com/Tr0snMCZ
wick
Postby wick » 18 Aug 2014, 23:45
PS: Rune 0.2 is running on my BBB *beautifully* - still *the best* music player OS out there, IMHO.
If 0.3 improves the sound - as I am sure it does - then it will be truly wonderful. Great work!
wick
Users browsing this forum: No registered users and 84 guests
