Postby exetico » 28 Aug 2014, 20:50
Great news! Thanks for the quick response, and again - all the work behind :D
Raspberry Pi with Rune, Synology NAS, OVH Debian Fileserver and a Shuttle HTPC.
exetico
Postby andy.room » 29 Aug 2014, 08:54
After having tried the 0.3 alpha release for some time, I have noted down the following problems:
1. AirPlay is visible by IOS devices or iTunes, but music is not heard when playing. The problem is exactly the same from iTunes on PC and iPad.
2. Database updates automatically every time the Raspberry is turned off and on again (not a major problem, but time consuming)
I apologize if the above topics have been already reported by other users.
Thanks for your kind support.
A.R.
andy.room
Postby wick » 29 Aug 2014, 16:53
OK, I've now tried 0.3alpha with r-pi and 3 dacs: pi-dac, hi-fi, and usb dragonfly.
I've had excellent results with all of them.
I've also tried both nfs mounts and local usb - no problems, though I've had to force mpd updating
for the usb mount, sometimes 2 or 3 times, before it seems to actually do anything.
It's really quite good already.
I had one question - I am sure that folks here will know - what's the std cookbook method to
expand the filesystem? The archlinux setup on the image is this:
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 2048 186367 92160 c W95 FAT32 (LBA)
/dev/mmcblk0p2 186368 3667967 1740800 5 Extended
/dev/mmcblk0p3 3667968 5668863 1000448 82 Linux swap / Solaris
/dev/mmcblk0p5 188416 3667967 1739776 83 Linux
So, I would typically use fdisk to delete p2 and then expand back out via resize fs, but was a bit
uncertain given the block alignments, and that swap space.
Thanks for any tips.
wick
Postby Aquarius » 02 Sep 2014, 13:09
-- Aquarius
Aquarius
Postby andy.room » 03 Sep 2014, 14:29
andy.room
Postby ACX » 03 Sep 2014, 14:51
Postby metalrob » 03 Sep 2014, 16:45
Hi, Runers!
Would you please implement TuneIn Radio? I think it's the best webradio provider. Would be great!
In case you do so- a lot of thanks :mrgreen:
Greetingz, Robert
metalrob
Postby ACX » 03 Sep 2014, 17:43
Postby davidgrundey » 03 Sep 2014, 22:04
Firstly thank you for this awesome programme. I've been running the 0.3 alpha for a while and haven't had any major problems.
WiFi adapter didn't work from start but have fixed this with help from this post.
NAS workaround works for me in the moment (not using NAS - only to test)
USB workes perfectly every time (WD Elements)
Webradio: Some Dirble stations work, some don't. Can not add stream .pls files.
It works this way:
Find .pls online
Download to desktop
Open in notepad
Copy link
Paste in runeaudio
Done!
Had a thing today where the "connecting" thing was spinning and the GUI was greyed out. I could ping the pi and access the GUI by going to 192.168.1.26/settings or 192.168.1.26/mpd etc but not click on anything.
Fixed it with ssh sudo reboot
One minor issue is when clicking the back button to navigate back to previous folder in the library it starts from the top of the list and not from the last item selected. Bit annoying with long lists of files.
Sorry if I have duplicated anything and thanks for your help.
davidgrundey
Postby ACX » 03 Sep 2014, 22:34
