Postby wick » 06 Sep 2014, 19:34
Perhaps you can help me understand this answer. So you mean that it takes a long time after a reboot for the wireless to acquire a DHCP address? Or does this mean that it takes several reboots before wlan0 starts up properly?
Thanks for helping me understand this.
wick
Postby cmh714 » 06 Sep 2014, 20:11
Postby davidgrundey » 06 Sep 2014, 23:57
davidgrundey
Postby nofx » 07 Sep 2014, 08:52
nofx
Postby spacemonkeyuk » 07 Sep 2014, 13:08
spacemonkeyuk
Postby grahamnewman » 09 Sep 2014, 08:20
1.5TB USB drive doesn't mount.
I am running the pi B+ with NTFS formatted 1.5 TB USB (1.1TB of music on it) and the drive doesn't mount. Everything else is fine.
Pastebin here: http://pastebin.com/Sg4DgMFU
grahamnewman
Postby ACX » 09 Sep 2014, 16:54
Postby cmh714 » 09 Sep 2014, 17:07
as ACX mentioned, it does work fine, as I have a 2TB NTFS USB working. Also as he said it REQUIRES its own power or thru a hub, the Pi doesnt have enough for it to work properly.
Postby Orion » 09 Sep 2014, 17:31
- Embedded Hi-Fi music player
Orion
Postby scaramanga » 09 Sep 2014, 20:51
I've got v0.3 working almost perfectly, with one minor issue.
The volume control in the web player is inactive and can't be controlled. Have tested this across different browsers, machines and OSes.
I suspect it's got something to do with the fact that I'm using a DAC rather than the standard audio jack on the Pi.
Can anyone help me figure out how I'd figure out how to solve this?
Many thanks.
scaramanga
