Postby vcelkamaja » 14 Sep 2014, 15:26
I have installed version 0.3 and what is good news Wifi connection works now. I wasn't able to use it with previous versions.
But it seems there are still 2 things which I'm not sure are ok:
1. I needed to use ethernet connection for the first usage to configure wifi connection. It didn't work with wifi only. However when I configured wifi, I can unplug ethernet and even after power off / on it works with wifi only. Perfect!
2. The second issue is that while using wifi only I'm loosing library after power off / on. I'm using music from NAS, I added library, scaned it and everything worked well. But when I power RPi off and then power it on again I can't access previously configured library (red cross next to library name). So I need to go to configuration and add the library again.
Anyone seeing the same issue?
vcelkamaja
Postby cmh714 » 14 Sep 2014, 16:01
1. that is standard, you cant configure the wifi if you arent connected so its done through the wired connection.
2. My guess is your wifi isnt fully up when MPD wants to index your files from the NAS. You can refresh that through the UI on the mount page. Maybe the guys could build in a timer for the wifi, to make sure its up before indexing....assuming that I am correct.
Postby skrodahl » 14 Sep 2014, 23:21
-skrodahl
skrodahl
Moderator
Postby Jorged » 15 Sep 2014, 10:28
Wifi not working with the usb wifi module TP-LINK TL-WN725N.
Jorged
Re: libraryHome BUG Fix
Postby nechtej » 15 Sep 2014, 18:24
nechtej
Postby twain » 15 Sep 2014, 22:47
for me Jamendo does not work. When I start a Jamendo Radio the play button goes shortly on "playing" and than back to "stop".
My Debug: http://pastebin.com/1ZdQWmjX
Ah and the "Copy Data to Clipboard" button does not work. When i press it firefox hangs up for a minute.
but its already a great piece of software!
greets, twain
twain
Postby scaramanga » 16 Sep 2014, 08:54
Sorry another thing.
I've got a network mount added, which appears to be connecting fine. By which I mean it appears on /sources/ with a tick next to it. On the 'browse your library' list page, it appears in the count (i.e. 'Network mounts (2)"), but the folder doesn't appear on the listing page.
Does anyone know what might be causing this?
scaramanga
Postby 4SFED » 16 Sep 2014, 23:36
I am seeing a similar issue to above with the network mounts. I have successfully added a mount, but in the library screen it shows no network mounts have been added.
However, if i do a search on my library the songs from my network appear. This is the only way that i can get access to this music on the network.
Additionally, after connecting a USB stick, it appears fine and is browsable, however after removing the USB it still appears connected. I cannot remove this, it is persisted after a reboot etc. The only way to clear this up is to re-image my SD card.
4SFED
Postby ACX » 17 Sep 2014, 00:46
Postby 4SFED » 17 Sep 2014, 05:05
4SFED
