Postby mikeoh » 18 Sep 2014, 12:39
I was having problems for a while with getting wifi to work with my network. Just realised its because the SSID contains spaces (duh).
Whenever I try to connect to it, it replaces the space with %20 and seems to think it is an unsecured open wifi network. Odder still, it claims to be connected (even though it is secured with WPA2 and therefore cannot be).
I live in a shared house so cannot change the SSID easily, is there an easy fix for this (other than using another SSID)?
mikeoh
Postby Aquarius » 18 Sep 2014, 13:15
"%20" is a space in the web world. This should be converted to "\ " or something like that when the SSID is passed down to the network tools. I'm pretty sure there's some easy way to do that. It's just a matter of using it.
-- Aquarius
Aquarius
Postby ACX » 18 Sep 2014, 14:42
Postby will-1 » 19 Sep 2014, 14:07
Hi, as my Dac is having problem to play songs with different sample rate, can anyone tell me how to force Runeaudio up sample all song to 96kHz/24bit?
will-1
Postby evozero » 19 Sep 2014, 17:39
Anyone experienced BBC streaming broken? I have 4 BBC channels in my radio list. They have been working fine and glitch free, I tried to play the below stream, that was working.
http://bbcmedia.ic.llnwd.net/stream/bbc ... 9848dd2118
It get added to the queue and shows in the playback screen, but the timer never buffers or counts like it did before, and of course no sound.
Tried reboots etc.
Any ideas?
Many thanks
Ian
evozero
Postby wick » 19 Sep 2014, 19:58
wick
Postby wick » 19 Sep 2014, 20:34
wick
Postby cmh714 » 19 Sep 2014, 21:49
If you have an issue with getting ntp to work, you can use timedatectl to set it correctly
Postby cmh714 » 19 Sep 2014, 21:52
Postby cmh714 » 19 Sep 2014, 21:53
you can also get around blank spaces in your ssid by using quotes is my understanding.
Users browsing this forum: Bing [Bot] and 5 guests
