Postby nofx » 11 Jul 2014, 16:21
nofx
Postby ACX » 11 Jul 2014, 16:27
Postby nofx » 11 Jul 2014, 16:48
runeaudio_debug.txt.zip
(17.4 KiB) Downloaded 614 times
nofx
Postby metalrob » 11 Jul 2014, 16:55
Hi Runers!
Great work! Great sound! Very promising!
BUT:
1)
Wifi is hard to install. To get 'add new mount'- is a randomplay. Suddenly I was able to specify my router, but several times it didn't work.
Edimax Dongle was very hard to install and afterwards it frequently has lost connection. I think it has something to do with it's power management.
It had to be disabled in Volumio to work stable. Probably you didn't think of this.
A logilink mini dongle worked immediately.
2)
Some radiostations I regularely listen to do not start at every klick.
When changing from one track to another- in my case from radio to USB files or vice versa rune crashed.
it happens again and again. Display then shows 'connecting'- animation. From this point it is impossible to get into rune again- reboot required.
3)
When running rune there are frequent connection losses- only for some seconds. That occurs I think 3 to 4 times in a minute.
If it contributes to good sound- I can live with it ;)
That is what I discovered in the relatively short test phase.
One thing: What really is massively disturbing is the blue information field that prevents me from viewing and klicking an additional button.
It takes much too long till it disappears. I don't need this info at all, it's completely unnecessary to me.
If there is no way to kill this function is it then possible to place it on a more neutral place? That would help.
Thanks for this tremendous efforts! It will be perfect soon! Again: Sound is great!
Is there rune audio planned for Cubietruck and Odroid U3? That are interesting platforms as I think.
Greetingz, Robert
metalrob
Postby ACX » 11 Jul 2014, 17:18
Postby buliway » 11 Jul 2014, 17:22
buliway
Postby dryce » 11 Jul 2014, 18:37
I am having this issue as well. The Nas is properly mounted and with a green check under sources. When I go into the Library area there is no mount point listed under Nas. When I click on it I just get the option to add a new mount point. I am at work at the moment, but will post logs later if it helps.
dryce
Postby Orion » 11 Jul 2014, 18:59
@buliway / @dryce / @emma (I suppose)
It seems your mount operation goes fine, but MPD did not updates the database.
Try to force the database update using this button (you can find it in /sources section).
force update button
- Embedded Hi-Fi music player
Orion
Postby nic » 11 Jul 2014, 19:30
I am struggling . I have downloaded the file but cannot see it with 7zip , file is currently on desktop . I had the same issues last time . It took me hours to work it out but I just cannot get my head round it . zip files I have no issue with but how on earth do I extract a .gz file . Help !
cheers
Nic
edit : idiot here has finally worked it out ! Next time I should fly through :)
nic
Postby ACX » 11 Jul 2014, 19:43
Users browsing this forum: No registered users and 70 guests
