Postby nic » 11 Jul 2014, 20:11
It's working and playing music but I'm finding I'm having to continually click refresh for the page to load . Hardware volume control not working with the DIYinHK XMOS soundcard I'm using , it's pinning me against the back wall no matter what setting , coming through at 100% with 6watt amps and 94dB speakers !!! Software volume works fine . Cover art is displayed . Will have a further play this evening
cheers
Nic
nic
Postby ICLlP » 11 Jul 2014, 20:18
I am listening to music for the first time using Rune with my HiFiBerry Digi. It's sounding good. Unfortunately mounting my HDD, attached to my iMac, via SMB/CIFS failed. I'd love this to work. I had to mount by NFS.
ICLlP
Postby ACX » 11 Jul 2014, 20:22
Postby ICLlP » 11 Jul 2014, 20:46
ICLlP
Postby Woodhouse » 11 Jul 2014, 20:55
hi all!
Great stuff.!! Is was a long wait, with daily checks of the forum,,,,;-) but now it is here.. Listening to some prime audio, while i type.
Beside things already mentioned i have 2 additional things to bring forward:
1: a mounted usb stick can not be removed from the interface after physically unplugging it, even after reboot. Trying to do so by the supplied menu item, gives no error, but it simply stays in the list of sources , even though it it is not physically connected.
2: dsd file can be played! But intermittendly (stutter). Maybe connected to mpd high cpu load bug.
Furthermore it would be nice if you included the 8892eu firmware fot the tplink 725 ii dongle.
Oh and the interface will not work in the default android webbrowser. In firefox it is fine.
Woodhouse
Postby ACX » 11 Jul 2014, 21:06
Postby buliway » 11 Jul 2014, 21:25
buliway
Postby nic » 11 Jul 2014, 21:35
I can't seem to cut and paste from Putty but the results are output 1 diyinhk enabled , output 2 (bcm2835 ALSA) enabled .
The wife is now home so I no longer have use of the front room :( Will continue tomorrow . Do you have an idea regarding the network issue ? I'm having to click refresh 3 times when navigating between pages . On the same page it's fine . Have cleared the ARP cache , browser cache etc but issue persists . Older version of Rune is fine and responsive . It may be an odd issue such as SD card . What do you recommend using ?
cheers
Nic
nic
Postby dryce » 11 Jul 2014, 21:38
dryce
Postby ACX » 11 Jul 2014, 21:43
