Postby rodgersan » 13 Jul 2014, 11:35
Hi there,
Really nice release. I have been waiting to update from raspyfi to runeaudio for a while. Theme improvements and new features, outputs options and integrated last.fm scrobbling are really nice. Playlists are now avalaible from mpdroid which is nice. I can not give any feedback about usb, wifi, airplay, playing high quality music (only 16/44.1) and other file format than flac unfortunately.
My setup is runaudio in dhcp (wired) getting a database of flac only from a synology using cifs. My output is a nuforce on usb. Whereas everything is working fine with raspyfi (no drops, hardware volume) I had to struggle as to have my nas mounted. It worked quite straightforwardly here. :)
Some thoughts though:
1/ already reported by tc-fi; ntp server does not update (/etc/ntp.conf checked) and no timezone selection / /etc/hosts not updated when hostname modified
2/ avahi support for the web interface
3/ mode consume gone (I don't know actually if it was there in the previous releases)
4/ local coverart (I have read somewhere on these forums it was available though) seems to be fetched from internet although I have cover.jpg and file embedded covers
5/ Audio buffer size settings says 2048 is default. However for me it was 1024.
6/ internationalization (well seems to be coming)
7) a way to update without flashing sd (or maybe a way to export configuration, database and playlists
8/ a library browsing through artists, albums and genre (and files).
Unfortunately I have a small issue which prevents me from using it. I can't adjust volume using any client. I tried to disable outputs with mpc but no luck. Using "alsamixer -c 1" works. Hardware volume is enabled.
Debug information:
http://pastebin.com/8SbZckj8
Well done!
rodgersan
Postby ACX » 13 Jul 2014, 11:55
Postby ACX » 13 Jul 2014, 12:02
Postby dmantel » 13 Jul 2014, 12:40
Hi! I have the same problem with Emma. I have shared folders with Windows 7 and web UI doesn't see them. I do update database resources but at the end my shared folders have a green check but in the library there are none. BUT I have on my smart phone the app mpdroid and everything looks as it should be there. The mpdroid sees all the files and the web UI none.I can see the library and even when I added a folder and had updated the database It appeared as it should (only on mpdroid app).
dmantel
Postby Devox » 13 Jul 2014, 12:59
Same Problem with "not showing any Songs from a network share". Absolutely same Setup as under RuneAudio 0.2: A Share with 50.580 Files in 4.743 Folders. - The Library doesn't show any of them, even after some "forced updates", but the Share shows up green under "sources". Maybe it's just too much? If that is the Case, I just wonder why 0.2 did it, and 0.3 can't.
Didn't do any more testing, without Music that would be rather pointless. But I'm Happy about the release and hope you guys keep on making the best player in the world. :)
Debug On Pastebin:
http://pastebin.com/HBbyGb8y
Devox
Postby skrodahl » 13 Jul 2014, 13:42
-skrodahl
skrodahl
Moderator
Postby ACX » 13 Jul 2014, 14:37
Postby rodgersan » 13 Jul 2014, 14:41
rodgersan
Postby Devox » 13 Jul 2014, 15:02
@ACX:
YES! They do! :D and they are complete and fully browsable. Nice, even if it is only for finding the bug, it's also a usable workaround for now. Thanks.
Devox
Postby buliway » 13 Jul 2014, 15:04
buliway
Users browsing this forum: No registered users and 53 guests
