Postby skrodahl » 14 Jul 2014, 11:42
-skrodahl
skrodahl
Moderator
Postby holliswhy » 14 Jul 2014, 11:44
Hi devs,
Quite a newbie with script etc here, but I am able to follow instructions.
I am running Rune Audio on:
Raspberry Pi, Synology NAS 212j, Chord Hugo DAC, 300B amp, and high efficiency speakers.
Running on LAN.
Installation was simple in OSX and Apple Pi baker.
This is a great release. NAS mounted without issues, no cracks and pop like 0.2, and I am loving the font update. Very pretty!
On a side note, I am running the Raspberry Pi on battery (for iPhone) and it sounds better to my ears. There is less "glare" and noise.
Thanks again to everyone here and especially the dev team.
If any testing is to be done, please let me know.
Cheers
Hollis
holliswhy
Postby skrodahl » 14 Jul 2014, 11:52
-skrodahl
skrodahl
Moderator
Postby Orion » 14 Jul 2014, 12:52
- Embedded Hi-Fi music player
Orion
Postby skrodahl » 14 Jul 2014, 13:18
Just for clarification, is the "Force Library Update" in "Sources" the same as an ordinary library update? To me, it sounds like it would wipe and rebuild the library.
-skrodahl
skrodahl
Moderator
Postby Orion » 14 Jul 2014, 13:29
Orion
Postby skrodahl » 14 Jul 2014, 13:48
-skrodahl
skrodahl
Moderator
Postby Orion » 14 Jul 2014, 18:40
Orion
libraryHome BUG Fix
Postby Orion » 14 Jul 2014, 19:57
Reason: added time sync section
Orion
Postby j-b-m » 14 Jul 2014, 20:25
I just tried the update procedure described by Orion. I had no issue with the Library since my music is on an usb drive, it appeared correctly. However, now with the update, on the library home page, the network mounts shows 1 mount despite no network mount. If I click on network mount, it brings an empty page (which is correct).
My problem with the playlist page showing only the first 201 songs is still present, the update didn't change that.
j-b-m
