Postby cmh714 » 01 Nov 2014, 21:31
I havent posted yet since release because I was out of town.
Flashed this morning and have been testing on a Pi B+ (havent tried in the B yet), first thing I did was the gitpull on Page 5, then walked through the UI setting everything up the way I need it, had the usual troubles with wifi (even though the UI is a ton better) I dont believe the code is working properly for hidden SSID but regardless copied my wlan0 profile from my alpha version and had wifi up in minutes. I didnt need to do any mods to get either of my DAC's working (AudioQuest DragonFly and Rotel RDD-1580) with files all the way to 24/192 (on the Rotel, the DF only goes to 96) working GREAT!!
A little surprised to see so many packages that need updating, but I will start another thread for that like I did for the alpha :) even if no one else looks, it helps me stay updated
GREAT Job you Guys!!
PS. only other issue I have is Jamendo just spins, but I really dont care....just stating :)
Postby amadeus74 » 01 Nov 2014, 21:46
amadeus74
Postby KHatfull » 01 Nov 2014, 22:58
Synology DS214+ -> RP3 -> Hifiberry Digi+ -> Audio-Gd NOS1704 (coax) -> Audio-GD C-2 preamp/headphone amp ->
1) Yamaha M-4 Power Amp -> Energy Pro 22 Speakers OR 2) HiFiMan HE-400i
Audio Nirvana!!!
KHatfull
Postby franz159 » 02 Nov 2014, 00:33
franz159
Postby johnbanks » 02 Nov 2014, 00:50
@ACX
Many thx for the beta release which I now have running – RPi B+/iqAUDIO DAC+/Wireless (Edimax).
It was quite a struggle in those first few hours – I experienced the same problems that emerged later in many forum posts.
But you fixed it – thx – the DEV page option for updating is just great. But it is quite obscure unless you are an avid forum follower. Why not present it as just another option under the MENU dropdown?
Prior to beta there were 16K+ downloads now there are 18K+ downloads – so that means approx 2K beta downloads. There are also 2K+ views of the beta topic on the forum – but many will be more than one time viewers. So many downloaders will not have seen ‘news’ of the DEV page option.
Just a suggestion – put a note on the download page about needing to do a DEV page update.
Or, just another suggestion – up load a beta 0.31 (and later 0.32 etc)
Again many thx for all yr efforts
johnbanks
Postby mashman » 02 Nov 2014, 02:22
Hi All,
I'm experiencing issue with airplay. The entire UI goes into a spinning lock after i attempt to send an airplay stream to rune. The system seems to be up with ssh and airplay available but i cannot access the UI or change anything.
I've replicated this on a vanilla install as well as my own attempted fixes(eg pacman -Syu, git pull, etc)
I....
ran a system restart rune_SY_wrk
reset the mpd.conf
ran a system restart rune_PL_wrk
hard reboot
and i'm still still spinning.
I managed to get around the spining wheel by deleting the div using firebug, otherwise i wouldn't have been able to provide this pastebin.
http://pastebin.com/E3fnnBBw
Anyone else experiencing this?
Thanks for all your work!
mm
mashman
Postby Orion » 02 Nov 2014, 02:27
- Embedded Hi-Fi music player
Orion
Postby Orion » 02 Nov 2014, 02:40
Orion
Postby mashman » 02 Nov 2014, 02:55
mashman
Postby cmh714 » 02 Nov 2014, 04:43
I dont know about anyone else but the wifi so far is fantastic. I havent dropped a 128 or even a 192 stream yet. Lightyears better than before. It has only been a day so far.....so we shall see :)
Users browsing this forum: No registered users and 40 guests
