Postby KHatfull » 02 Nov 2014, 07:19
Synology DS214+ -> RP3 -> Hifiberry Digi+ -> Audio-Gd NOS1704 (coax) -> Audio-GD C-2 preamp/headphone amp ->
1) Yamaha M-4 Power Amp -> Energy Pro 22 Speakers OR 2) HiFiMan HE-400i
Audio Nirvana!!!
KHatfull
Postby Thak » 02 Nov 2014, 08:45
I manage to make WiFi work this morning! (one great victory ^^)
But... My share folder still won't show-up on runeaudio (but it shows-up on anything else, computer,etc...)
Tried to change MDP to "root:root", no change.
Here my debug :
If someone have a clue on this...
Thx!
Thak
Postby valery » 02 Nov 2014, 09:21
Hi! Another big (in my opinion) trouble - it's fixed IP option. It dont work! After I set fix IP, I can't see Rasp in network (and in the router clients too), and I need only make a new SD with RuneAudio for repair it.
DHCP is no good for any MPD-client (like MPDroid), becouse it need to know exact IP-adress.
valery
Postby Bjarne » 02 Nov 2014, 09:26
[quote="valery"]Hi! Another big (in my opinion) trouble - it's fixed IP option. It dont work! After I set fix IP, I can't see Rasp in network (and in the router clients too), and I need only make a new SD with RuneAudio for repair it.
DHCP is no good for any MPD-client (like MPDroid), becouse it need to know exact IP-adress.[/quote
I solved that at the rooter by dedicating the PI a ip address .
/Bjarne
Bjarne
Postby valery » 02 Nov 2014, 09:36
valery
Postby siam28 » 02 Nov 2014, 09:52
siam28
Postby ICLlP » 02 Nov 2014, 10:22
I've experienced two issues.
1) I can ssh into Rune, but sudo shutdown -r now does't work. "Command not found".
Others are obviously succeeding with ssh, so is the solution already available somewhere?
2) AirPlay from YouTube to Rune, worked well, but caused the Rune UI to freeze (circling arrows), but MPaD continues to work. Because of 1) above I will have to turn the Pi off and on again at the mains and hope the SD card doesn't get corrupted. It didn't last time.
ICLlP
Postby hondagx35 » 02 Nov 2014, 10:58
Postby tux » 02 Nov 2014, 11:01
Or even better:
systemctl poweroff
Sent from my Oneplus One
tux
Postby ICLlP » 02 Nov 2014, 11:33
ICLlP
