Postby ICLlP » 02 Nov 2014, 11:35
ICLlP
Postby tux » 02 Nov 2014, 11:38
systemctl reboot
Sent from my Oneplus One
tux
Postby ICLlP » 02 Nov 2014, 11:54
ICLlP
Postby bambadoo » 02 Nov 2014, 13:27
Hi again. The mpd database "auto update". I am setting this to yes but when I add music and folders to my music library. No "auto update" is catching this. Need to do a manual update.
bambadoo
Postby yok3 » 02 Nov 2014, 17:24
Hi all
I been here before, have try 0.3 when it was at test mode but it didn't work for me...
now I have installed 0.3beta and it look nice, but ;
- I'm useing rPi with Najda DSP over I2S output
- I have problem to have only mono via I2S and Rune 0.3
- i have had sime problem with ''volumio'' the solution was to set I2S output from ''volumio'' to 32bit / 44.1 or 48kHz
(I set under "playback" - " resampling " to 32bit/44.1khz)
is there some way to set that on Rune ?
thanks
yok3
Postby valery » 02 Nov 2014, 17:51
I think that the very usefull option for new RunAudio wil be a not only "Power Off", but "Power On" function trough MPDroid, sound@home or any other MPD client. It will be great!
valery
Postby cmh714 » 02 Nov 2014, 18:07
Postby cmh714 » 02 Nov 2014, 18:10
ACX or anyone that knows, I want to mess with the Interpolators as I assume with no setting in mpd.conf that means its using the default of Fastest and I would like to try Best. Unfortunately, my hand edits keep getting overwritten during a reboot. I think that is coming from redis but not sure.
How can I keep my edits from getting stepped on?
tia
Postby cmh714 » 02 Nov 2014, 18:17
ACX, I see what appears to be an error/typo in the dev_ctl.php code, see snippet below. I assume the reset MPD Config shouldnt be pointing at netconfreset :)
// ----- RESET NET CONFIG -----
if ($_POST['syscmd'] === 'netconfreset') $jobID[] = wrk_control($redis, 'newjob', $data = ar
ray('wrkcmd' => 'netconfreset'));
// ----- RESET MPD CONFIG -----
Postby ACX » 02 Nov 2014, 18:23
