Postby challenge » 04 Nov 2014, 14:10
Ok, then it's a feature request: easier way to batch add and manage webradios and keeping the UI automatically in sync with MPD library.
BTW I don't get what you mean by "coherency with other MPD clients" by making the addition to redis db only manually by UI.
Shouldn't webradio that are on MPD library appear also on runeUI, to be coherent with clients?
I use mpdroid and if I go to library»files»webradios I can see all the files in the directory/library, even the ones I batch-dropped there that runeUI is not showing, and it can play all of them too (after updating library obviously).
gmpc it's the same, sonata too, I tried windows clients too and it's the same.
They access webradios directly from MPD library...
I don't get why the manual db addition in runeUI "is the only way to keep a coherency between the RuneUI and other MPD clients"... the mpd clients just read the webradio folder from library and nothing else, or I'm wrong and I'm missing something?
Where's the coherency if runeUI doesn't have webradios in redis db that mpd already has in its library?
I'm a layman, I know I oversimplified everything. I don't want to criticize, just learn and understand :D
EDIT: i think I got it... you're thinking on UI side: radios added by UI should be made available to mpd, and this works.
While I'm thinking the other side, the UI must read what's it's in mpd library. This isn't working.
I don't use guis a lot and prefer the speed of just dropping a bunch of radio files there xD
I guess it should work both ways to call it done... :mrgreen:
challenge
Postby johnbanks » 04 Nov 2014, 15:22
@ACX
Would it be possible to have DEV as an option in the MENU drop down list?
Thx
johnbanks
Postby asturnauta » 04 Nov 2014, 16:34
asturnauta
Postby ACX » 04 Nov 2014, 17:01
Postby cmh714 » 04 Nov 2014, 17:01
You are correct, the "enable" command parameter sets the profile for netctl so thats what makes it stick. You need to do the same for wifi as well.
You can see whats available and enabled by using: netctl list
Postby bambadoo » 04 Nov 2014, 17:33
It is often said that software volume control degrade the sound. But if it is enabled and set to 100 will it then degrade anyting?
BTW: Is the hardware volume control in some dacs better than software?
bambadoo
Postby johnbanks » 04 Nov 2014, 17:46
@ACX
Is it planned to fix a couple of annoyances?
When I power up it is necessary to Remount All Sources to get access to my NAS library
Also even tho' wireless is working, it is necessary to Refresh Interfaces in order to get a green tick against WLAN0
Just annoyances to me, I know but probably quite confusing to new users
Thx
johnbanks
Postby ACX » 04 Nov 2014, 17:51
Postby ACX » 04 Nov 2014, 17:52
Postby matt » 04 Nov 2014, 19:59
matt
