Postby AndreR » 07 Nov 2014, 09:53
AndreR
Moderator
Postby hondagx35 » 07 Nov 2014, 10:00
Postby Thak » 07 Nov 2014, 16:47
Ok, so my router come from my internet provider (SFR) and it's an NB6v, but i don't think this will help you, i'm afraid.
On the other hand, i didn't know that i must mount myself my HDD, i did it with RuneUI (set up my router ip, name folder, change some param to "root:root") but only just a very few folder shows up and no music file (.flac/.wav/.mp3... nothing), if i need to mount it throught SSH, can you point me to somme "how to" ?
sory i was a little bit upset, it's been almost 1 week that i'm fighting with this !
Thak
Postby Stwert » 07 Nov 2014, 16:49
If the folder shows up, do you see an updating spinner over the library button at the bottom? It's possible you need to wait for it to finish indexing before the music will all show up. Might not be the problem, but just thought I'd suggest it.
Stwert
Postby Thak » 07 Nov 2014, 17:33
I've waited all night and same result.
The updating arrows are shown only... Maybe 5minutes after that just à bunch of folders shows up (and always the same folder)
I've tried with just one folder on Hdd and I see the folder but no music file...
On raspbmc, with exact same install I can see my music file for exemple :/
Thak
Postby cmh714 » 07 Nov 2014, 17:38
go to the mpd config in the menu and see if the ffmpeg plugin is enabled...if it is, that slows down the update process so try disabling it.
Postby Thak » 07 Nov 2014, 23:04
I'm testing right now, i will edit with the result!
Edit :
Still the same.... here my http://pastebin.com/AGDW5GED if it's help...
Thak
Postby cmh714 » 07 Nov 2014, 23:17
your log still shows it as enabled...
Postby Thak » 07 Nov 2014, 23:23
Hum, i don't think this line means it's enable : "cifs_mount failed w/return code = -101"
i tried to add a mount flag "sec=ntlm", but no result
Thak
Postby dryce » 08 Nov 2014, 00:23
dryce
