Postby Thak » 09 Nov 2014, 01:50
Yep name is test your right :-)
And format is (as far as i know) vfat32
I don't know what means the "v"....
Anyway... On Rune i set ip on 192.168.1.1 for my router (logic) and path/name is just " test" and it mount almost correctly! Folder ok, file ko...
Thak
Postby dryce » 09 Nov 2014, 02:40
VFAT is short for virtual file allocation table. It is a driver. It basically functions as a go between between a application and a file allocation table. It isn't the format of your drive. If you haven't actually formatted the drive it is probably FAT32. It is kind of a strange issue you're having. Do you have upnp turned on in the router settings? I would connect the drive to your Ubuntu machine and double check the permissions on the music files. If they have somehow been placed under the ownership of a single user rather than giving access to "Everyone" it could explain the issue your seeing.
dryce
Postby ACX » 09 Nov 2014, 02:45
CUE files are now supported in the RuneUI - they are showed and they can be added to playlist.
Commit: https://github.com/RuneAudio/RuneUI/com ... e42548ed1a
As usual, please test it and leave a feedback.
Postby Thak » 09 Nov 2014, 08:59
I just check this morning and "permission" on my hdd seems to be lock on "none"... And i can't change them with my ubuntu machine, i will try with a windows one later today to change them.
Thak
Postby bambadoo » 09 Nov 2014, 09:07
bambadoo
Postby sykodad » 09 Nov 2014, 09:16
sykodad
Postby bambadoo » 09 Nov 2014, 11:12
Date is ok.
Just had to restart and then it worked fine.
BTW: Still have problems reaching http://runeaudio/ or http://runeaudio.local/
Have to use IP http://192.168.0.193/
Any suggestions?
bambadoo
Postby Beelzebassie » 09 Nov 2014, 12:27
Beelzebassie
Postby Woodhouse » 09 Nov 2014, 12:54
Hi there,
Just here to report that I stayed around after the initial glitches and must say it just sounds fabulous with my hifiberry. Also the ui has not suffered freezes after the gitpulls. Everything including my usually problematic TP-link 725n vII dongle works fine! SO I am quite pleased and impressed for that matter! Only really minor issue ist that it will not audibly play any DSD files (I have have only 3 for testing). It does seem to play and some rumbling and recognizable audio is played at extremely low volume, but it is not usable.
But when looking at at the practical side of things:
Could it be a good option to replace the download image with an up to date one under the same name? At this time I am quite reluctant in advising fellow audio enthousiasts in downloading rune because of the trouble in the initial 29 oct image. For people with less linux knowledge it is quite a struggle to get thought the ui freezes and remain enthousiastic enough to not get discouraged and keep going.....
So would it be a big deal to replace the current download with one that fixes the main trouble till thusfar?
Woodhouse
Postby ACX » 09 Nov 2014, 13:04
