Postby BorGreiner » 09 Nov 2014, 14:02
I find the 0.3 beta quite polished allready.
One odd thing that could be debugged is that every time I launch my Raspberry RuneAudio I have to "REFRESH INTERFACES" and "REMOUNT ALL SOURCES" if I want to play a last autosaved queue (or anything at all as a matter of fact). Strange thing is that I can connect through WIFI even before it is ticked green (after remounting all sources). Would be nice if that REFRESH and REMOUT would be done automatically at every start of the system.
BorGreiner
Postby evozero » 09 Nov 2014, 14:56
Great job Rune team on the beta release!
Have my IQ Audio DAC up and running without too much hassle.
PS I dont have the issue with both audio outputs enabled, the IQ Dac is the default and only enabled output?
A fresh install followed by these step and the system is very stable.
1) gitpull
2) clear OPcache
3) restart rune_SY_wrk (and wait for the notification to confirm it)
4) restart rune_PL_wrk
I have enabled hardware volume control, the sound quality is better, but the usable range is the last 10% on the volume control. Probably just a setting somewhere?
I do have an issue with streaming BBC radio, would someone try this stream as I know it works from a few other devices;
http://bbcmedia.ic.llnwd.net/stream/bbc ... 121cd12b89
Nothing happens when I play it?
Great job so far!
Many thanks
Ian
evozero
Postby ACX » 09 Nov 2014, 15:28
Postby dryce » 09 Nov 2014, 18:27
dryce
Postby dryce » 09 Nov 2014, 19:03
dryce
Postby cmh714 » 09 Nov 2014, 19:13
edit the udevil.conf file for file permissions....been discussed many times
Postby dryce » 09 Nov 2014, 23:39
I'm having some strange issues since the latest git changes. When I click on some of my files in the UI instead of listing the tracks I get a spinning wheel and the list never populates. It only happens on some and I haven't found a common link as to why yet. The log: http://pastebin.com/YJyQJv9w
Update: If I add the folders that do not display properly to the Queue they display and play just fine. When I search the database those tracks appear in the options as well.
Thanks.
dryce
Postby Beelzebassie » 10 Nov 2014, 11:38
Beelzebassie
Postby ACX » 10 Nov 2014, 12:11
@dryce and @Beelzebassie: could you check for Javascript errors in the console of your browser?
Postby Beelzebassie » 10 Nov 2014, 12:23
Beelzebassie
Users browsing this forum: Baidu [Spider] and 31 guests
