Postby amadeus74 » 17 Nov 2014, 20:19
amadeus74
Postby ACX » 17 Nov 2014, 20:49
Postby markl » 17 Nov 2014, 22:59
Hi ACX, I had everything working reasonably well until this evening's gitpull, but after briefly enabling the hardware mixer then disabling it again the sound has completely disappeared. I've checked "alsamixer" and "mpc outputs" in a ssh session and both seem fine. I am running an external USB DAC (Epiphany Acoustics). Also, the MPD spinning wheel has returned. Any suggestions? Pastebin attached.
Regards (and thanks for reminding me about alsamixer a couple of weeks ago - it was indeed responsible for the low output)
http://pastebin.com/3kMD1LD7
markl
Postby taizen » 17 Nov 2014, 23:09
hi ACX,
It is a Beresford DAC2 HGC.
But don't worry, about the usb with Raspberry, I will install a Hifiberry DIGI+ on it. I Think it is easier.
My aim is to compare at least the Rasperry with Digi+ and the Udoo with USB (when available), and take the best of the two.
Best regards
Taizen
taizen
Postby taiebot » 17 Nov 2014, 23:28
I am having issues with streaming some local radios. My local radios are available via a tvheadend server https://tvheadend.org/ which is on my local network (raspbmc with tvheadend configured). When i play them they look like to buffer for few sec and being released very fast making them scratchy like if you were scratching an old vinyl disk.
I wonder if i have to buy the mpeg2 codec as it is the format use to broadcast the radio. I have past experience with that and normally without the codec purchased, the sound should be played but the picture should be absent. As it is a radio stream i shoud not have to buy the codec and i do not think it is related to this but i can be proven wrong.
As a note, this was working on a different music platform for the pi without the codecs.
taiebot
Postby pba » 18 Nov 2014, 00:22
pba
Postby ACX » 18 Nov 2014, 00:47
Postby ACX » 18 Nov 2014, 00:48
Postby pba » 18 Nov 2014, 01:17
pba
Postby ACX » 18 Nov 2014, 02:55
