Postby ACX » 18 Nov 2014, 02:59
Postby amadeus74 » 18 Nov 2014, 08:55
amadeus74
Postby pba » 18 Nov 2014, 16:55
pba
Postby markl » 19 Nov 2014, 21:09
markl
Postby ACX » 20 Nov 2014, 01:57
Postby mikma » 20 Nov 2014, 19:29
The non-stopping spinning "Connecting"... Apparently it's a wifi-issue.
I was having RJ45 plugged in my raspi and it worked just fine. The moment I booted up with only wlan connected (which doesn't work automatically after boot, need to run 'systemctl enable netctl-auto@wlan0.service') the Connecting keeps on showing. The Library shows songs but when I add them, the Queue is empty. And so is the Playback. Controls in the Playback also don't work.
Raspberry Pi Model B, Rev 1.
Bus 001 Device 005: ID 0586:341e ZyXEL Communications Corp. NWD2105 802.11bgn Wireless Adapter [Ralink RT3070]
'git pull' -> Already up-to-date.
mikma
Postby shakey102001 » 21 Nov 2014, 14:09
Hi i did the last update but after the update cannot do anything
spinning arrows keep spinning:-(
into dev mode i reset everything still no better:-(
If i want to reboot it says
Warning
The loading layer (spinning arrows) points to a socket error
But does not reboot
After hard reboot i get the same problems, i am afraid something whent wrong with the update (never had problems before with the spinning arrows like this)
I can only enter the dev page cannot enter any of the other pages, in safari the dev page it keeps giving met the message repeatedly after 3 seconds
Warning
I use a Raspberry B with iqaudio pi-dac, cabled network (ethernet) and NAS as music source no wifi
Hope this helps?
shakey102001
Postby Stwert » 22 Nov 2014, 02:58
I've just started having a weird problem where the interface will continually have spinning connecting arrows, but I can see in the background that the layer is stuck on Airplay.
If I go to the dev page and restart stuff, I can see that it is on MPD and then quickly switches back to Airplay.
If I hit Reboot from the dev page, I get a warning "The loading layer (spinning arrows) points to a socket error".
Stwert
Postby hondagx35 » 22 Nov 2014, 13:42
Hi Stwert, hi shakey102001,
have you tried to refresh your browsers cache ( Ctrl-F5 )?
Postby Klausi69 » 22 Nov 2014, 13:50
I can confirm this effect: When using Airplay, the spinning arrows are always on (with FF and IE on Win7, Chrome on Android 5). Refreshing browser cache doesn't change anything.
Klausi69
Users browsing this forum: No registered users and 62 guests
