Postby shakey102001 » 24 Nov 2014, 10:28
Hi hondagx35, have refreshed even used a different browser witch had never opened runeaudio
shakey102001
Postby wick » 24 Nov 2014, 19:41
wick
Postby cmh714 » 24 Nov 2014, 19:56
Yeah I play 24 bit 192k files all the time with no problem through my Rotel DAC via USB. The USB drive is plugged into a powered hub.
Postby taizen » 24 Nov 2014, 23:28
Hi Wick,
I use a Benchmark HGC2.
With Udoo and Archphile I have no problem to read music stored on mys NAS Synology.
Achphile is good but not easy to use, and there are not enough radio.
It is why I prefer Runeaudio that I have already installed on an other Raspberry B+ which works fine with HifiBerry Dac+.
I have planned to use a Raspberry with HifiBerry Digi+, and I hope that my problem will be solved.
In fact, I wait for Runeaudio on Udoo, but ACX has a lot of work and so we do not know when the release will be available.
taizen
Postby Stwert » 25 Nov 2014, 23:19
Stwert
Postby cmh714 » 25 Nov 2014, 23:26
I dont use airplay, but I think thats the shairport service so you could try disable it with systemctl stop shairport and disable it from starting automatically with systmectl disable shairport
not sure if that will work based on how the scripts startup rune.....
Postby hondagx35 » 25 Nov 2014, 23:32
Hi cmh714,
one thing you can try is:
- ssh to your pi
- execute "redis-cli hset airplay enable 0" without the quotes
- reboot
Postby cmh714 » 25 Nov 2014, 23:48
its not for me :) but thanks for the info. I need to understand redis a bit better anyway.
Postby Stwert » 25 Nov 2014, 23:52
Sadly, neither of those solutions worked, cmh714 and hondagx35. Still the same situation. I suspect there's probably nothing for it but a reinstall, though it seems I'm not the only one with this issue.
Stwert
Postby cmh714 » 26 Nov 2014, 00:07
if it is the shairport service you could try renaming the executable /usr/bin/shairport to something else
