Postby anadigi » 10 Dec 2014, 15:17
Thanks for the recent update!
Now I can use the IE to control the Rune now
I love the spins when loading! Looks cool! 8-)
anadigi
Postby cmh714 » 10 Dec 2014, 19:37
I am getting an odd error with git pull atm using the UI...not sure if I was successful or not...
RuneUI updated successfully
error: Your local changes to the following files would be overwritten by merge:
app/libs/runeaudio.php
app/templates/playback.php
assets/js/runeui.js
db/index.php
Please, commit your changes or stash them before you can merge.
Aborting
Updating d84ea1e..398764a
Postby cmh714 » 10 Dec 2014, 19:43
Also as a test I did a fresh flash and have ONLY done git pull no pacman updates and I unfortunately get the spinner upon bootup. The only thing that fixes it is restarting the rune_PL_wrk task via UI or cli. Almost seems like a possible timing problem....not sure if anyone is seeing the same...
Postby dwijtsma » 10 Dec 2014, 22:37
About my previous post, 2 days ago: SD card was broken... The only problem that stays now I have a new SD card is an empty library tab. :(
I can fix this using ctrl+F5, but I have to do this very often. I am using the latest version using GitPull. I use FireFox 34.0.5 on Windows 7. Furthermore I have the feeling That Vo***** 1.2 which fitted on an old 2GB SD card responds much faster.
I like to use RuneAudio because it looks much better and has many good features and an active community. But this empty tab and a much slower response is very unpleasant.
But overall, good work! Many great improvements and good support on this forum! :mrgreen:
PS: My two colleagues really like the concept and the convenience.
dwijtsma
Postby ryanmcclure » 11 Dec 2014, 00:27
I updated RA via CLI and restarted the PL and SY services via systemctl. I can confirm that the spinning arrows still occur on the Android stock browser and other browsers, including: Dolphin (without Jetpack), Light Browser, Lightning Browser, Javelin Browser. I can see the new spinners underneath the large arrows, however. Reset cache on all browsers as well. Can anyone else confirm this behavior?
Ryan McClure
Raspberry Pi Model B + RuneAudio + HifiBerry DAC + Lepai LP-2020A+ + Bose 141 Bookshelf Speakers
ryanmcclure
Postby popov » 12 Dec 2014, 01:01
HI
to dwijtsma, not vey clean, but with IE, change cache parameter to very you have a new version each time you visit .....
popov
Postby dwijtsma » 12 Dec 2014, 08:30
I'm using Firefox on my PC and also tried IE and Chrome. They all have the same issue, but on my Ipad (using safari) I don't have the problem. I'll try to play around with the cache parameters, but if cache is cleared every time I leave the page, won't it take very long to load the page? I know that ctrl+F5 takes at least 30 seconds.
Probably it's something with my PC since it looks like I'm the only one with this problem. Makes me feel special :o
dwijtsma
Postby ACX » 12 Dec 2014, 16:50
Fixed the problem of wrongly displayed web radio cover (thank you hondagx35 for pointing out the typo!):
https://github.com/RuneAudio/RuneUI/com ... 8172e2fe69
Postby dwijtsma » 15 Dec 2014, 23:00
Issue with Firefox 34.0.5:
I already told that Firefox has issues with the rune audio library tab, but I found out a few interesting things:
- I can fix the empty library tab in Firefox by starting Google Chrome and go to runeaudio.local. The library tab is fixed directly every time.
- I can do the same with Firefox. I open a second Firefox tab and go to runeaudio.local. The library tab is fixed in the first browser tab. :o On the second tab the library tab is also empty. But now it comes: I open a 3th browser tab and go to rune audio and in the second browser tab the library tab is fixed. :P
Last option feels even more like magic: When the library tab is empty in the firefox browser. Loading runeaudio.local on the tablet fixes the empty library tab in Firefox...
I don't have much knowledge about website development, but I thought this could be helpful.
dwijtsma
Postby terasain » 19 Dec 2014, 18:24
Just installed 1.3 beta and every things works beautifully. I am using a hifiberry dig+ feed a Beresford Bushmaster MKII DAC. Love the new browse by album functionality on the Library tab and sound is top notch. I moved my setup from Raspberry Pi B to B+ and the previous USB HD setup failed to work. I read that there is a config change to /boot/config.txt that might increase the power to USB from 500mA to 1200mA.
https://projects.drogon.net/testing-set ... erry-pi-b/
Do you know if this will work with runeaudio distro. Just trying to avoid a usb hub and the subsequent clutter.
terasain
Users browsing this forum: Bing [Bot] and 45 guests
