Re: RuneAudio 0.3-beta for Raspberry Pi - Issues with iPad 1
Postby franz159 » 22 Mar 2015, 10:03
Hi everybody,
do you have any idea why with with an iPad 1.0 I have the dreaded "spinning wheel" while connecting issue?
I have the same problem both with Safari and Chrome.
I'm using a Raspberry B+ with Rune 0.3. Beta.
If of any help, if I go to the /dev page (from iPad 1 Safari/Chrome) it works.
Then I tried a git pull from there and I got a repeated message like "...invalid socket....."
On my Ipad 3 both Safari and Chrome do work.
Any idea?
franz
franz159
Postby ACX » 22 Mar 2015, 12:04
Postby franz159 » 22 Mar 2015, 15:32
franz159
Postby andy.room » 13 Apr 2015, 16:59
Every time I boot the RPI the MPD database will automatically update...this is quite annoying when I want to play a HD flac without waiting the update to be completed (during the update the HD flacs do not play smoothly). Does anybody know a way to disable this feature? I wish to start Rune with the last saved database and just perform manual updates only at my command. Thanks in advance for your help.
andy.room
Postby hondagx35 » 13 Apr 2015, 18:38
Postby andy.room » 16 Apr 2015, 11:51
andy.room
Postby a.dent » 24 Apr 2015, 07:59
I am attempting to get Rune working on a Raspberry Pi2.
I have absolutely ZERO computer knowledge or experience.
Please help.
With my heart in my mouth I followed the instructions to flash the SD card.
It all seemed to work OK but I can't connect with my browser.
I checked the router for IP addresses and the RPi does not show up.
I have an HDMI screen attached to the RPi and the second last line says
"PANIC: VFS: Unable to mount root fs on unknown-block(179,2)
Entering kdb (current=0xee460000, pid 1) on processor 1 due to Keyboard Entry
(1)kdb"greater than symbol"
a.dent
Postby Aquarius » 24 Apr 2015, 09:00
The 0.3 release that you are probably using is for Raspberry Pi A/B/B+ only, not 2. There's a thread on this forym about the Raspberry Pi 2 with SD card images to flash for you. The next release (0.4 ?) will be compatible with all Raspberry Pis
-- Aquarius
Aquarius
Postby a.dent » 24 Apr 2015, 09:14
Thanks Aquarius
I went to http://www.runeaudio.com/download/ and downloaded the one linked from Raspberry Pi 2.
Are you saying that download doesn't actually work for the Raspberry Pi 2?
a.dent
Postby Aquarius » 24 Apr 2015, 09:44
Actually I had not seen this link before. That should be what you're looking for.
Reading your first message, it's probably a problem with the sdcard image. You may want to flash the downloaded image again on your sdcard and verify that there are 2 partitions inside.
-- Aquarius
Aquarius
