Postby elmer » 23 Sep 2016, 21:56
I figured out why the files weren't updating - my mpd is running as mpd, not root ... In the last couple days I used recursive SCP to the root account to transfer folders of music into the USB drive. Transferring OGG files from Linux worked; rebuilding the library reflected the updates. Transferring mp3s from Windows didn't work; both files and folders are given root ownership, not necessarily with access for other users.
Here's a file that doesn't show up:
-rwxr-x--- 1 root root 12137099 Sep 23 22:45 '/mnt/MPD/USB/music/Various Artists/Classic Rock Broadcasts and Live Recordings - 100 Classics/68. Born to Be Wild (Live).mp3'
Here's a file that shows up:
-rw-r--r-- 1 root root 4836792 Sep 23 13:36 '/mnt/MPD/USB/music/David Bowie/Best of Bowie/Disc 1 - 1 - Space Oddity.ogg'
Then I changed the permissions a+rx for:
And changed the permissions a+r for the mp3 file.
After that, the file was seen.
elmer
Postby knottydreadbr » 03 Dec 2016, 19:22
knottydreadbr
Postby dynobot » 27 Dec 2016, 23:12
Lee Iacocca the CEO of an automotive company once said "In the car business, you lead, follow, or get out of the way."
I think the same is true in the audio business.
With that said if anyone is looking for a very similar sounding piece of software Arch-Linux base...Moode Audio just came out with a version that has Squeezelite, this means Spotify and all other music services are ready to go out the box. I have it up and running right now, and it sounds great. All the usual HATS etc work too. :D :D
dynobot
Postby Yatsushiro » 28 Dec 2016, 11:28
I don't think Moode is Arch based, isn't"t it raspian Jessie lite?
Yatsushiro
Postby dynobot » 28 Dec 2016, 15:29
Ahhhh you are right. I don't know where I got Arch Linux for Moode from.
Not that it makes a whole lot of difference but there might be pro's and con's of Debian vs. Arch.
I've played around with Jessie Lite and it seems to be pretty solid with a lot of 'working' features....also seems to be a large community base, actively being developed and pretty good support.
Another plus is BBB owners should be back in the game as I just installed the latest version of JessieLite on my BBB.
dynobot
Postby dynobot » 28 Dec 2016, 21:54
dynobot
Postby pietpara » 14 Jan 2017, 16:10
pietpara
Postby hondagx35 » 14 Jan 2017, 18:09
Hi Pietpata,
there are two versions TL-WN823N V1 and V2.
V1 (ID= 0bda:8178) uses the Realtek RTL8192CU chipset for which a driver is available.
V2 (ID= 2357:0109) uses the Realtek RTL8192EU chipset for which no driver is available (without compiling it).
Postby pietpara » 15 Jan 2017, 19:28
pietpara
Postby Yatsushiro » 15 Jan 2017, 20:04
Yatsushiro
Users browsing this forum: No registered users and 39 guests
