Postby metalrob » 01 Nov 2014, 10:53
Hi all!
Revision of revision: Discovered some bugs:
If I'm switching between 2 webradio stations I have stored in the playing queue rune audio often stucks- looses connection.
Then a reboot via ssh is necessary.
Sometimes it happens, that radio stations I've stored under 'My Webradios' aren't shown, or only one (I've stored 2) is shown.
Also it happens from time to time that stations that are selected do not appear in the playing queue. Then I have to repeat the selection.
Further I have to remember, that first time installation and adjustment is still tricky. Wlan connection is really hard to get and I see no 'masterplan'
in doing this save. It seems to connect after a long time playing around or sometimes shorter. one time it even connected immediately after doing the settings- thats pretty driven by random.
Also the MPD setting does not really work after saving changes. Fortunately the settings are stored after ssh- reboot
Audio output, allthough i2s selected show hdmi or onboard after restart. That is practically not a problem thanks to the fact that anyway only one output works- and i2s is always working despite of the wrong indication.
Generally there is some instability in the system.
Greetingz
metalrob
Re: RuneAudio 0.3-beta for Raspberry Pi - exfat
Postby franz159 » 01 Nov 2014, 10:57
As per my previous post
runeaudio-0-3-beta-for-raspberry-pi-t502-60.html#p3148
Does anyone have a hint on what I should to to mount (and automount) an ExtFs formatted USB disk?
It was working with 0.3 alpha, but it's no longer working with 0.3 beta.
This 2Tb disc contains all my Flac... for the moment I mounted a samba share from another device where I have less space (still 1Tb) so I do have a lot of my music.
Nevertheless I would like to find a long term solution.
Thanks for any help
franz
franz159
Postby andy.room » 01 Nov 2014, 12:20
Thanks to the RuneAudio developpers team for this nice beta release. I wish to ask which DLNA server is working on windows XP in order to use this new feature on RPi. Thanks.
andy.room
Postby valery » 01 Nov 2014, 14:32
Hi! I see that DAC 9018 k2m (i2s connection) do not support again? It'a pity :(
And how I can see HDD, connect with USB-Sata link to Raspberry, in network devices (for copy or delet files)?
valery
Postby ACX » 01 Nov 2014, 15:54
Postby ACX » 01 Nov 2014, 16:01
Postby ACX » 01 Nov 2014, 16:04
Postby ACX » 01 Nov 2014, 16:06
Postby ACX » 01 Nov 2014, 16:09
Postby ACX » 01 Nov 2014, 16:12
