Postby Multi » 18 Mar 2017, 18:36
I reported earlier about latest image:
When selecting a stream or track in the queue, Runeaudio locate that track in the middle of the queue list.
That movement is often not straight in one movement and more nervous than i was used to in former versions.
Am I the only one who has problems with it? I downgrade because of this weird behaviour.
Multi
Multi
Postby hondagx35 » 18 Mar 2017, 19:19
Postby hondagx35 » 18 Mar 2017, 19:25
Postby R101 » 18 Mar 2017, 20:55
Thanks for the improvements. The only problem I have had is that the Android app sometimes seems to stall for several seconds when selecting a file or stream. This might be nothing to do with Rune, but It has not happened before. Operation from a browser seems slicker than before and I have not seen the same problem with it.
The only modification I have made is the waves library navigation change, which I hope will become standard at some stage.
http://pastebin.com/hea0Cuaw
Postby gearhead » 19 Mar 2017, 07:56
gearhead
Postby gearhead » 19 Mar 2017, 08:50
I think I may have fixed theCIFS mount problem. I added "sec=none" to the mount flags and it then mounted. We will see for how long.
Gearhead
gearhead
Postby mo86 » 19 Mar 2017, 09:53
Hi Frank!
There's a bug I found in queue-list.
On smaller resolutions total playtime info is showed about 2 lines, see picture.
Thanks a lot!
mo86
Postby Multi » 19 Mar 2017, 10:27
It is independant of which browser is used. Even in the Android app i have this behaviour.
I had never troubles with it and going back to an earlier version (4.4.39-1-ARCH / 6.2.1. 20160830) again no problems?
Multi
Multi
Postby hondagx35 » 19 Mar 2017, 11:51
Postby c-moll » 19 Mar 2017, 13:24
When I choose the info of a title (the little "i" beneath the album cover) and then click on "Read more on Last.fm", I get on the web pages of Last.fm. But how can I get back to runaudio's gui? I can see no close-button or anything else.
btw: Thx for this new beta, great job!
Chris
Raspberry Pi 3B - HifiBerry Amp+ - Raspberry Pi 7" Touchscreen
c-moll
