Postby hondagx35 » 19 Mar 2017, 18:45
Postby dougF » 19 Mar 2017, 21:12
Just tried the latest version with the Access Point. It works great!
I did notice one issue that maybe you guys could take a look at.
When operating the raspberry Pi 3 in Access Point mode from my iPhone, whenever I click the iPhone button that puts it into standby, the audio on the raspberry pi is briefly interrupted but returns to normal within a few seconds.
Keep u the great work!
Doug F
dougF
Postby cr73 » 19 Mar 2017, 21:20
hello has all I have a problem, alpha 4 after installation, I changed
boot.confiig the files and installed drivers hdmi-lcd 4 "Waveshare,
to reboot remains fixed on starting .... RUNEAUDIO, and can not connect to ssh, as if it blocks the connection or another, what can 'be, thanks.
cr73
Postby c-moll » 20 Mar 2017, 11:09
Raspberry Pi 3B - HifiBerry Amp+ - Raspberry Pi 7" Touchscreen
c-moll
Postby robertinjo » 20 Mar 2017, 16:40
Is there a new RuneAudio 0.4 image file that can be used with NOOBS or berryboot for a multi boot purpose ?
robertinjo
Postby Boz » 21 Mar 2017, 16:16
I am trying to setup RuneAudio 4.x (latest) on a Pi3 with the Pi Foundation 7" LCD with touchscreen.
Here are my issues.
Trying to setup a DHCP connection and I can enter my wifi information but when I enter the information and click on save profile nothing happens. If I switch to another window and come back into settings nothing has changed in regards to the Wifi.
Using the interface randomly the screen becomes white and seems like it freezes. With other distribributed Operating Systems the touch screen does not exhibit these issues at all. Also I have a HiFi Berry DAC installed but I don't see the audio output selection for it in the menu.
That's about as far as I have got with testing it since I cannot get a wifi connection. These setups are going in each room connected to Crown DSI 2000 amps with Boston Acoustic speakers. Will there be support later on for GPIO settings? I would like to turn some relays on/off so I can turn the amps on/off that are connected to the PI's remotely rather than leaving an amp on that draws ~6amps just at idle.
Thanks -Boz.
Boz
Postby neanderthaler » 21 Mar 2017, 22:30
I'm also fighting with wireless on my Pi2...
AP when starting works great, so I created a fresh music database, a playlist, everything working fine at first glance.
When I create a wlan-profile and try to connect, AP is switched off and there is obviously no connection established. After a hard power cutoff and restart the AP comes up again - but the stored profile is gone.
neanderthaler
Postby mo86 » 22 Mar 2017, 04:51
@neandertaler: had the same problem after creating a wifi-profile. I had to disable the access point manually in settings to make my wifi-profile work.
mo86
Postby hondagx35 » 22 Mar 2017, 11:29
Postby c-moll » 22 Mar 2017, 17:25
The screensaver works a little bit funny. He comes for only half a second, then switches back to the normal playback screen. Can anyone confirm this?
Chris
c-moll
