Postby R101 » 29 Mar 2017, 10:29
Can you give some idea of how long it will be before we can listen to .M3U8 streams with Rune?
Postby gearhead » 29 Mar 2017, 14:15
I am not too sure about what stream is what but I think that the current pi2 install supports it on the back end and if you can point to it, it should just play it. I am listening to a 320kbps stream now. Is this M3U8?
If you have a M3U8 stream you can post to me, I''ll see what is up with it.
Gearhead
gearhead
Postby R101 » 29 Mar 2017, 16:05
Thanks Gearhead. It's the BBC streams I am thinking of, so you need a UK IP source to get access.
This http://a.files.bbci.co.uk/media/live/ma ... music.m3u8 works in VLC but does nothing in Rune.
Some info here: http://iplayerhelp.external.bbc.co.uk/r ... s_bitrates
Postby ianhaynes » 29 Mar 2017, 17:30
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby n8dgr84 » 30 Mar 2017, 08:36
I have the new Hifiberry Digi+ Pro on RPi3 and have it working but I'm wondering which i2S kernel module to use in the settings tab?
Will both "Digi/Digi+" and "Digi Pro" work equally for the Digi+ Pro?
Would be nice if there was one "Digi+ Pro" to reduce confusion :lol:
n8dgr84
Postby R101 » 30 Mar 2017, 09:58
Postby hondagx35 » 30 Mar 2017, 10:55
Hi R101,
we "only" have to recompile the mpd package with the option enabled.
Let me see what i can do.
Postby jesper » 30 Mar 2017, 22:07
So, I don't get AirPlay to work in 0.4b using I2S set to Boss DAC. It shows RuneAudio in the network on all other units (computers and iOS devices) in the network, but refuse to connect to it. I did restart after changing I2S setting.
Others experienced the same?
Any workaround?
jesper
Postby n8dgr84 » 30 Mar 2017, 22:53
Make sure under Settings>Features management> Airplay is ON
n8dgr84
Postby jesper » 31 Mar 2017, 00:35
Sure, it's on. Still not working.
jesper
