Postby Vhond » 28 Apr 2017, 17:54
https://github.com/hondagx35/RuneUI/issues
Thx, it will also prevent double questions when it's clear what's under development.
Vhond
Postby Vhond » 28 Apr 2017, 19:48
Vhond
Postby gearhead » 28 Apr 2017, 20:02
Vhond,
This is a 'feature' of shairport. You may try stopping the service from 'Settings', deleting the /run/shairport directory and pipe (rm -rf /run/shairport), restarting rune_PL_wrk service from the runeaudio/dev page then restarting the shairport service from settings. it *should* fix it at least temporarily. The real fix is to go to shairport-sync, but it is not trivial to implement.
Gearhead
gearhead
Postby Vhond » 28 Apr 2017, 20:23
Vhond
Postby gearhead » 30 Apr 2017, 01:11
vhond,
moode uses shairport-sync. it is much more robust than shairport.
Gearhead
gearhead
Postby Vhond » 30 Apr 2017, 07:59
Thx, thought RuneAudio and Moodeaudio used the same, maybe a feature request for RuneAudio 0.4 :?:
Vhond
Postby DHMC » 01 May 2017, 05:26
I'm using Raspberry Pi 3 (Model B) with RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB.img connected to a router with access to internet via a cable modem. There is long freeze on the screen on many features(play a new song, select "Settings" etc.) when internet access is not available like disconnecting the ethernet cable between router and modem.
Is it a known issue?
DHMC
Postby Fif91 » 01 May 2017, 16:19
Is it possible to integrate this , in the next release?
Fif91
Postby VD2000 » 02 May 2017, 12:23
VD2000
Postby DHMC » 02 May 2017, 18:25
DHMC
