Postby Leigh » 02 May 2017, 19:24
All seems very good, but:
my volume control is very nonlinear - there is almost no sound until about 85%, then it increases to 100%.
The genre list is out of order on android only - EDIT: Sorry, no it isn't - its the folders on my external HD that are not in alphabetical order on Android only (my music file structure starts with Genre folders)
RPi3
IQAUDIO DAC+
Leigh
Postby Aquarius » 03 May 2017, 08:30
I've parsed through this thread and noticed that nobody asked about good old Raspberry Pi 1....
Is there a 0.4 build available for raspi 1 ? I couldn't find it. My setup is rather old (rasp 1 B (not "+") with Hiffiberry Digi (not "+") soldered on, so my upgrade options are limited.
Kind regards,
Olivier
-- Aquarius
Aquarius
Postby hondagx35 » 03 May 2017, 09:21
Postby Vhond » 03 May 2017, 15:35
Vhond
Postby hondagx35 » 03 May 2017, 15:48
Postby uwedamm » 03 May 2017, 16:01
Hello Frank,
that must be a fulltime job ... wow, thank you really much for the rune-audio.
Like promised here is my hint regarding SB11040 (soundblaster USB soundcard):
Within mpd.conf the following lines are generated in a wrong way:
audio_output {
name "USB Device 0x41e:0x30d3"
type "alsa"
device "hw:0,"
mixer_control ""
auto_resample "no"
auto_format "no"
enabled "yes"
The device line should be:
device "hw:0,0"
This issue was discussed in the past once:
support-for-creative-usb-soundcard-t343.html
maybe if there is some "low-prio" fix-list for the rune-audio, you can add it there?
Everything else works just fine for me. Just some finetuning I will try to perform myself:
1) "CTRL-Alt-F1" for opening a shell does not work any more
2) Within the graphical output, I cannot see a mouse-cursor ... I expect this is due to optimization for touchscreens ...
Uwe
uwedamm
Postby uwedamm » 03 May 2017, 16:33
I got a tty-shell login using:
systemctl start getty@tty4.service
For permanent access:
systemctl enable getty@tty4.service
And than CTRL-Alt-F4
systemctl start getty@tty1.service
and even 2,3 does not work, but I dont know why ... in my next life I would like to be the linux professional:-)
Uwe
uwedamm
Postby hondagx35 » 03 May 2017, 20:25
Postby uwedamm » 03 May 2017, 20:37
yeah got it, thank you Frank!
Why did you remove CTRL-ALT-F1? Does it fail somehow?
Btw: I got a fix in the runeaudio.php to fix my SB1140 soundcard bug (see my other post) ...
I am really happy with runeaudio now, just waiting for my HIFIberry DAC+ pro to arrive (together with the parts for the power-supply :-) Unluckily reichelt let me wait:-(
Uwe
uwedamm
RuneAudio 0.4-beta for Raspberry Pi2/3 : Dac selection issue
Postby zorglub » 05 May 2017, 15:45
I have tried the new version of Rune (20170229) and I am facing asmall issue. I first selected a "HifiBerry DAC" into the scrolling list (even if actually my DAC is a ESS9023 based DAC from Audiophonics). So far so good, afterall this option was working fine with the previous Rune version. Then, I moved to the MPD CONFIGURATION MENU but the first box "Audio output interface is stuck": I could not select my DAC. (Actually you have to select your DAC twice?)
Thanks for helping me
zorglub
