Postby coley 20001 » 21 May 2017, 14:27
Hi everyone
I am complete novice when it comes to this kind of thing but I managed to get my raspberry pi 3 with allo boss dac up and running following the info from the forum so would like to thank all involved with rune.
Coley20001
coley 20001
Postby foogaamoo » 22 May 2017, 22:02
Tested it on RPI2B with IQAudio DigiAMP+. Could you add hardware unmuting if you pick IQaudIO PI-DAC+ for i2s kernel modules section on the settings page?
It's a broken experience for the casual or new user having to manually do these steps:
[root@iqaudio ~]# echo "22" > /sys/class/gpio/export
[root@iqaudio ~]# echo "out" > /sys/class/gpio/gpio22/direction
[root@iqaudio ~]# echo "1" > /sys/class/gpio/gpio22/value
So far really enjoying the password login as this device is being used in a shared network for web radio and airplay. Kudos for all the effort!
foogaamoo
Postby luamiennam » 27 May 2017, 04:11
luamiennam
Postby Cyclopse » 27 May 2017, 20:43
Rasberry Pi 2 and version 0.4b build 29feb2017
Problem with the Spotify interface. I can see the playlist and when I select a track no audio and fails to play. Read about changing audio interface to analogue and back. However, I only have my USB dac listed in the audio output interface, no other options in the drop down box.
Any suggestions most welcome.
Cyclopse
Cyclopse
Postby hondagx35 » 28 May 2017, 11:30
Postby donimo » 29 May 2017, 14:28
Thank You for the update.
Like a couple of other users, the screensaver feature where the UI changes to artist info and lyrics is not functioning reliably.
I have the latest 0.4 build, Raspberry Pi 3 and a Waveshare 5" HDMI display.
You did mention a few pages back it may be a touchscreen issue - do you have any further information or help?
The same thing happens on my local browser running chrome on a PC, which is definitely not a touchscreen!
donimo
Postby hondagx35 » 29 May 2017, 17:05
Postby donimo » 29 May 2017, 19:30
donimo
Postby SeanWu » 31 May 2017, 08:03
Is 20170229 the latest build for RuneAudio 0.4 beta?
I just get Allo Boss DAC and want to make sure that this build is compatible with the DAC.
SeanWu
Postby hondagx35 » 31 May 2017, 11:28
Users browsing this forum: Bing [Bot] and 14 guests
