Postby johnberg » 03 Aug 2017, 11:10
johnberg
Postby kolia » 05 Aug 2017, 08:49
kolia
Postby Frost_dk » 05 Aug 2017, 10:10
Hi all.
Does any of you have problems with making changes such as airplay enable/disable, changes to mpd, and such trough the web interface? The changes are not getting saved properly :(
And when I turn on the rpi, I have to rebuild music lib, before it shows in network connections. When this is done, it plays music as it should. But only until I connect to runeaudio.local from another browser (my phone/ iPad or another computer),then the music stops, and the web interface shows a blank interface again.. Almost like it resets, and shows a new session..
I have had this problem before, when I first tried this 0,4 beta image... But now I thought I would give it another go, but it is the same problem :( it is a shame as I like the new additions Frank has put into it :)
Kind Regards,
Rune
Frost_dk
Postby hondagx35 » 05 Aug 2017, 22:01
Postby Frost_dk » 05 Aug 2017, 22:07
Frost_dk
Postby hondagx35 » 05 Aug 2017, 22:11
Hi frost_dk,
please post your debug info.
Postby Frost_dk » 05 Aug 2017, 22:16
Thank you Frank.
here it is :
https://pastebin.com/LyQVxb8K
Kind regards,
Frost_dk
Postby hondagx35 » 05 Aug 2017, 22:34
Postby Frost_dk » 05 Aug 2017, 22:40
Thank you Frank, you are the man :)
Yes both i2s and USB are enabled.. I have been running som tests between I2S and usb, if I could tell the difference .:)
I am sorry to have troubled you with my own mistakes. I thought that I already had expanded the SD card.. I will try it again.
Again Thank you for your big effort in helping us all :)
Kind regards,
Rune
Frost_dk
Postby andfor » 21 Aug 2017, 21:05
Been using Rune 0.4Beta on my RPi3 for a while now and am really happy with it. Huge thanks to the devs for the hard work in putting it together and keeping maintenance going. And for taking the time to deal with all our questions!
Here's my question:
When I first enabled Global Random it worked as expected, playing random songs at the end of the queue. So far so good.
Problem is that after I stop listening and then come back later, it gets to the end of a different queue and the same list of songs plays again when the global random kicks in.
This happens after a reboot also. The random list is the same every time. Same songs in the same order.
Whenever ashuffle starts it plays the exact same list from the beginning.
Is this what is supposed to happen? I've read through the info at https://github.com/Joshkunz/ashuffle and it seems to me this shouldn't be the case. Maybe I'm wrong. Any info would be great. If you need debug info let me know.
Thanks!
andfor
Users browsing this forum: Baidu [Spider] and 38 guests
